Results 1 to 8 of 8
Thread: Does everyone else's screw that hold in the rudders and trim tabs not have bolts?
    Apr 2011
    VA
    134
    Default Does everyone else's screw that hold in the rudders and trim tabs not have bolts?
    Looked in the exploded views and they show nuts on the inside of hull to hold in the screws but mine does not have them.Wondering if it is supposed to be that way or if they forgot to put them on mine?
    Please respond Grim or anyone else that has there boat.
    here is a pic
    May 2008
    1,744
    Quote Originally Posted by bdp1174 View Post
    Looked in the exploded views and they show bolts on the inside of hull to hold in the screws but mine does not have them.Wondering if it is supposed to be that way or if they forgot to put them on mine?
    here is a pic
    I am guessing you mean nuts? If that is the case it looks fine. Just like the SuperVee set up. Those plates you see are threaded and act as the Nut to hold everything on.
    Apr 2011
    VA
    134
    Yes I meant nuts sorry.Ok so does yours look the same?Thanks again
    Brandon
    Apr 2012
    MD
    77
    Mine is the same, I believe electric is correct, the plate is threaded.
    Apr 2011
    VA
    134
    Ok thank you very much.I am gonna give mine a once over tonight and grease up the flex so I can hit the water with it hopefully tommorow.
    May 2008
    1,744
    Yeah, it is fine, do check each one to make sure they are snug. I just did mine a few minutes ago and all of them needed about a turn or so to tighten them up a bit. I might go run mine this evening also, trying to talk my son into braving the Texas heat.
    Nov 2008
    WI
    662
    The replacement hardware sets come with tapped plates and nuts.
    Grim
    May 2012
    MA
    21
    Mine is the same way too,quick question anyone have severe chine walk i can barely keep it in the water?
