Results 1 to 10 of 10
Thread: castle spartan esc
    Jul 2011
    141
    Default castle spartan esc
    for my spartan boat, I got 140 amps on a 6 s 5000 mah 20c lipos, I can run 6s all day and motor or esc wont get hot! why did castle put 13 guage wire on this esc?? why not 12 guage?
    Feb 2011
    AB
    775
    What are your battery temps?
    5000mah 20C batteries are designed to only discharge safely at up to 100 amps max. (give or take depending on quality, the accuracy of manufactures ratings, and whether or not they also have a burst C rating))
    If you are pulling 140 you could be seeing some significant resistance in the batteries.
    Your ESC and motor might be running cooler because they are not getting full current.
    Kevin
    Jul 2011
    141
    yes, I will get 30c or 40c next time or more capacity ones, what do you run i there?
    Jul 2011
    141
    pulling 88-90 amps on 4s with stalk prop.
    Feb 2011
    AB
    775
    I run 5000 mah 45-90C batteries, and a turnigy 180 amp ESC.
    In one spartan I run a leopard 4082 1500kv motor on 6s and in the other I run a castle 1515 2200kv motor on 5s. (current setup. I change it up now and then to experiment)
    Kevin
    Jul 2011
    141
    hi, are you getting 4 beeps than red. red green for low voltage startup everytime you run your castle spartan esc?
    Jul 2011
    141
    is the turnigy 180 amp boat esc programmable with hobbywing card?
    Feb 2011
    AB
    775
    Quote Originally Posted by 4343 View Post
    The turnigy 180 amp marine ESC and hobbywing/seaking 180 amp ESC are the same ESC, just badged differently, so the hobbywing programming card should work with the turnigy esc.
    Kevin
    Jul 2011
    141
    Kevin, do you get 4 beeps ,than red red green beeps for lipo start up on castle spartan esc?
    Feb 2011
    AB
    775
    I've never used the Castle Spartan ESC. I stripped the OEM ESC, motor, and radio out of both Spartans when new and installed aftermarket equipment.
    Sorry I can't provide any feedback on this for you.
    Seems there are very few participating on the forum right now, try asking over at the Spartan forum on the Traxxas website.
    Kevin
