On the ESC, you would be better off just leaving the single black and red wire and putting the appropriate contact on each. You can then series your batteries together with their leads...
On two 2S packs, if you plug one of the battery red leads into the black lead of the other pack, you will now have a 4S1P pack. Then you plug the ESC leads into the appropriate remaining battery leads and you are all set...
Pretty simple, and no adapters required...
Darin E. Jordan - Renton, WA
