Page 3 of 9 FirstFirst 12345 ... LastLast
Results 61 to 90 of 256
Thread: "that" miss geico
  1. #61
    Aug 2010
    MO
    1,173
    Will do. And sorry guys. Forgot the camera. Maybe with my phone
    Sent from my SPH-D700 using Tapatalk 2
  2. #62
    Aug 2010
    MO
    1,173
    So full throttle. Plug in battery... Nothing. Servo.works but not motor. Whatelse can i try and it didnt.let smoke...
  3. #63
    7,633
    That is odd.That is a PB ESC eh?
  4. #64
    Aug 2010
    MO
    1,173
    Turnigy 120 aquastar esc.
  5. #65
    7,633
    Totally not familiar with those.Got to go out for the day.Talk later
  6. #66
    Aug 2010
    MO
    1,173
    Ok. Ill keep messng with it. Maybe something will work
  7. #67
    Aug 2010
    MO
    1,173
    So.going to test the esc on a differe.t motor. That way i know if.its the esc.or motor...
  8. #68
    Aug 2010
    MO
    1,173
    Well esc is bad. What now?
  9. #69
    7,633
    Get an ESC.And get a T-180 or Seaking 180,they are the same.That way you can prop up later.
  10. #70
    Aug 2010
    MO
    1,173
    Kinda figured. What kind. No castle esc.
  11. #71
    Aug 2010
    MO
    1,173
    What brand is the t180?
  12. #72
    7,633
    Quote Originally Posted by masonis1 View Post
    I'm pretty sure the T stands for Turnigy.I think that is why everyone refers to them as T-180's.It's a Hobby King thing. The 180 is what I would get.You already pooched a 120.All it would take is for your flex to bind a bit with a bigger prop and there goes another 120. Oh yeah,how many runs did you go before regreasing the shaft?
  13. #73
    Aug 2010
    MO
    1,173
    Ibhave about 3 runs in the grease now. I should re grease it.
  14. #74
    7,633
    I do mine before each day out.I pull them out at the end of each day.I have seen some of the flexes rust when sitting in the tube.
  15. #75
    Aug 2010
    MO
    1,173
    The stuff i put on prevents rust... Oh wow. Ok my bad
  16. #76
    7,633
    Not all of them.It must be the quality of the flex.Oddly enough,my most expensive flex's to date.The ones I got from Randy (BBY) are awesome.Removeing them is just habit now and greasing them is my morning ritual.Along with COFFEE.
  17. #77
    Aug 2010
    MO
    1,173
    Ok cool. Hah i.need a thicker grezse cuzbthis stuff now is just a little thicker than wd40 and it flings out around the collet. I have an oil.stain all the way around the hull on the inside. Hah
  18. #78
    7,633
    I picked up some Lucas marine Blue grease and it works awesome.I'm good for 4-5 runs and the shaft still has some on it when I pull it out.
  19. #79
    Aug 2010
    MO
    1,173
    This stuff is from ofe and seems good
  20. #80
    Aug 2010
    MO
    1,173
    So looking for a esc now. Starting to miss my crawler too so I need to get a small lip for that and I'm also missing my brushless rc10.need to make a 5.5 mm bullet adapter to think 4 or 4.5 so I can use my ezrun 150a esc on my rc10. Busy but its summer now...
  21. #81
    Aug 2010
    MO
    1,173
    So now my big truggy is gutted of everything except the motor. Almost roller. I'm wondering if that.motor can fit in the mg and if the t180 can take it?
  22. #82
    7,633
    Is that the Tork?If so,no problem,With a X645
  23. #83
    Aug 2010
    MO
    1,173
    No it is a castle mamba monster 2200 kv
  24. #84
    7,633
    So it is a 1515 like mine,same as mine.That'll push a 645.I'm going to try more this weekend.I'm going to lake country.
    If you end up wanting it to live in the MG I could make a mount for you.But to try it the stock mount will work.But soon very soon you will need to support the motor better.
  25. #85
    Aug 2010
    MO
    1,173
    So id need to get a mount for it. What about cooling with the fins
  26. #86
    7,633
    OSE sells the cooling can.
  27. #87
    Aug 2010
    MO
    1,173
    Are these 5.5?
    Here is the cc1515
  28. #88
    7,633
    That is factory Castle ? Then they are 6.5's. And here is the cooling can.http://www.offshoreelectrics.com/pro...ham-castle1515
    I got to go to work.
  29. #89
    Aug 2010
    MO
    1,173
    No those are from the ezrun esc. How can I measure them first?
  30. #90
    Aug 2010
    MO
    1,173
    They measure 6mm on the esc. And the motor plugs are the same. Is that 5.5?
