Im sorry the b is by the space and so is the period. Hah and i try typing fast and that doesnt help. What i asked was, the strut and rudder assembly on my first build boat seems better than the.MG. Can i change them or should i is what im asking
Sent from my SPH-D700 using Tapatalk 2
I would leave well enough alone.That looks like a great place to run to me.Probably walking depth for retrieval and everything.
A couple spots it gets deep but where the clear water is, it was no higher than 3 feetball the way across. Great place.
So did you run the little guy?
No. Im kinda scared to run that thing. I.need to do some sealing testa
Does it sink in the middle of ponds.and sink?
Don't know yet,it is still a bare hull.I learned years ago to make sure that can't happen.But I sunk a few learning that
That's the new home of the Tork 2200.
How can i seal it up even nore
motors 005.jpg Use some of this on the lip where the hatch runs against the hull.It is sticky on one side.Did you have floatation in it?
Yes. The hull was just filled with water
What happened there? You double posted 10 mins apart and I got chucked into my last post.Mmm,strange.
What
I like the new avatar.
Thanks shawn. Looks sweet. Hah
Well this weekens will be another great boating weekend. Have a perfect spot at the gasconade river. About a 1 mile stretch of water just.perfect. Hah either that or at the y where the missouri and gasconade join. Hah that will be fun.
So shawn. My cousin wanted me to convert his blast to brushleas. I made it kinda work. He neess a esc, and lipo and charger.
Seems to all fit.
He is looking for a esc. He is using the turnigy 2700 motor i have. What esc? He is really worried about going cheap and it doesnt nees to.be over 4s lipo and im guessing 60 amps. Something cheap he can get. He will mostly use a 7.2 nimh hah just wanta brushless..
I would guess HobbyPartz or HK for the cheap.
What about http://www.hobbyking.com/hobbyking/s...oat%5FESC.html
That looks like a fine one Mason.
I wonder how fast it will be. Same motor, same prop as my first boat. Just a smaller battery and esc and a hella lot smaller hull.
Mason...Your dream come true ..https://forums.offshoreelectrics.com/...66-Lotsa-props!
Jim is awesome and I know he is getting out of this stuff for health reasons.
Thanks. Well the problem now is... Ran the boat. Ran great. Brouht in to check temps fine so sealed up amd pushed out to.run again and nothing. Now when.i.plig in the lipos. No beep tone but the servo.works. I dont know wjat happebed. Any thoughts!
Umm.. Try recalibrating.Hold the trigger on Tx and turn on/plug in boat.
