Results 1 to 26 of 26
Thread: Eagletree 150 amp to 300 amps in 15 minutes
    May 2008
    OH
    774
    Default Eagletree 150 amp to 300 amps in 15 minutes
    You can, on the wire lead ET, loop 12 ga. wire from esc side directly to batt. side bypassing the board entirely for both the +100_0052.jpg100_0051.jpg and - . This will bypass current, about 1/2, and let it run much cooler. You now have a 300 amp logger!
    Those are 8mm connectors.
    Next you need to access a Clamp on amp meter, clamp it around the battery leads and run the system up for 15 seconds or so logging the data and compare the amp readings between the them. The ET will have a reading of about 1/2 half of the clamp on meter.
    Now connect your ET to the computer, go to "Advanced programming" click on "Calibrate volt and amps" and enter the actual readings in the appropriate boxes and save.
    That all there is to it! Welcome to the 300 amp club!
    Recorded 283 amp burst with 192 amp average.
    Works great and is very easy to do.
    Try it you will like it.
    MI
    3,117
    Thanks for putting this up Jim! I will eventually make this change to mine so that I can get some decent data from my Q sport hydro...
    Question – How does this change affect the logger when going back to P-Limited type set ups? Meaning is the fidelity of the readings equally good compared to an unmodified Eagle Tree Data Logger?
    Thanks,
    Mike Ball
    Dec 2009
    TX
    2,040
    Is the current offset a percentage? Just wondering how thats gonna work??
    Nov 2009
    WA
    2,038
    Quote Originally Posted by oscarel View Post
    It could be if you wanted to scale the readings over the entire range measured. What ends up happening is the value you enter in after taking the half current reading will be offset to some degree, since wire, connectors IR and temperature are not compensated for over the operating range. But that amount is probably so insignificant who really honestly cares? I know, I know. Then whats the point of mentioning it? Just to put in perspective. This should be made in to a sticky for all to see if they want to mod their ET.
    John
    Change is the one Constant
    May 2009
    CA
    535
    So basically you added a shunt and then used a clamp-on ammeter to calibrate the readings?
    May 2008
    OH
    774
    I used a load, light blubs at 40 amps, to calibrate. A higher load might be better, however I have had no problems. I haven't seen any difference from 4s to 8s. Remember we use these to compare different props, batteries, hull settings, ect. I don't care if it's 3 or 4 amps off.
    Jan 2010
    VA
    1,218
    Dumb question, what you happen if you added another wire in parallel with the
    first wire installed on the ET?
    Jul 2011
    UK
    1,021
    Thanks for posting this. Can't believe I didn't think of it myself. That will give me something to do tomorrow
    Everything that has a beginning, has an End
    May 2008
    OH
    774
    Carl, the idea is to bypass 1/2 the amps form the ET.
    Jul 2011
    NY
    1,556
    I did this quite some time back and it worked great on my systems that pulled high Amps but when tried with my lower amp setups I got data that was inaccurate sometimes and other times it was pretty close but for high amp setups it is a great modification and works well
    May 2008
    OH
    774
    Humm, I use it on everything from P Limited to S hydro and haven't seen anything, except the usual have to keep the sensor plugs clean on the Logger. They can cause strange readings when they get loose or dirty.
    Jul 2011
    NY
    1,556
    Jcald I tried everythng to get it rite but I no longer have the eagle tree as I just traded it to a good friend and most of my setups use castle hydra ice hv and lv controllers but I was wondering if you could shed some info on how you put the system under load for calibration efenpics will be great I am thinking about getting another one and my way of calibrating was a little different
    May 2008
    OH
    774
    I calibrated by using 20 car tail light blubs soldered on brass rods, left over from our Nicad days over a decade ago, equaled 40 amps at 12 volts on a car battery.Loaded it for about 30 to 45 seconds to allow the bulbs to warm up and get stable reading.
    How much load did you calibrate at?
    Feb 2012
    NC
    163
    jcald, any chance you can make a quick sketch of your schematic? I think I understand what you are describing, but I like to be sure. Thanks.
    Disclaimer: I hereby accept the potential loss of motor, ESC, entire boat, or credit rating, and forfeit all expectations of success.
    Dec 2009
    TX
    2,040
    Quote Originally Posted by jcald2000 View Post
    So just verified with an EagleTree data recorder with 300 amp expansion and it's definitely very close!! I calibrated the elogger at 40amps while charging a lipo and once calibrated both recorders showed almost the same graph after a test run. Very nice find!
  16. #16
    May 2008
    OH
    774
    How high can it go??
    I just recorded a 372 amp peak for about 2 seconds when my 6s2p sport hydro submarined on launch.
    Don't want to do that again!
  17. #17
    Dec 2009
    TX
    2,040
    I was only able to get around 190 before the mod then the solder would melt off normally on one of the negative terminals. So that puts it around 380??? Did that spike have a flat top?
  18. #18
    May 2008
    OH
    774
    Yes!!
  19. #19
    Oct 2011
    DE
    332
    Going to try this thanks
  20. #20
    May 2008
    OH
    774
    A friend of mine bought a used ET on line that used a short 8 or 10 gauge as the shunt. Remember, the resistance must be the same for the additional wire, 12 gauge only and the same distance with a good solder joint.
  21. #21
    Jun 2014
    1,516
    Question, I don't have a high output charger, but I could in theory hook up my eagletree between my charger and the lipo pack I apply a charge to and then hook it up to the software in order to calibrate? My charger is capable of 5 amps max per channel.
    NEVER SATISFIED RACING
    Fine Design 32 V-Hull 4082+6s
  22. #22
    AZ
    8,010
    Two-year-old thread, and the OP hasn't logged on in five months......good luck.
  23. #23
    Mar 2015
    CA
    1,262
  24. #24
    ma
    8,693
    Quote Originally Posted by dmitry100 View Post
    thats pretty nice.
    Steven Vaccaro
  25. #25
    Jun 2014
    1,516
    Just waiting on parts, I am going to use a plane propeller to simulate about a 50 amp load on the motor with my shandard ETV4 150 amp logger to track. Then I should be able to take my modded ETV3 (Will be 200 amp version when I finish the modification above) and calibrate with the same load.
  26. #26
    May 2008
    Oz
    2,981
    Have fwd that link to my daughter .. father's day is coming up
