Results 1 to 9 of 9
Thread: upgrades
    Apr 2012
    Md
    121
    Default upgrades
    Hi guy's... I just ordered me a impulse 31 should be here next week.
    But in the mean time i would like to order some of the needed upgrades.
    so far from all my reading i should upgrade.
    5.5mm bullets
    flex cable
    collet / coupler
    trim tabs adj.
    prop x645, 42x55 grim racer, 45x55
    can anyone help me out with links or part #
    and is there anything else that i need to do????
    Aug 2010
    wi
    1,461
    I would just upgrade the bullets and prop, I never had a problem with anything else.
    Apr 2012
    Md
    121
    That sound good to me
    What prop you running?
    Apr 2011
    tx
    1,284
    the 42x55 may work but the others are way to much prop for stock setup. That or bring a fire extinguisher.
    Aug 2010
    wi
    1,461
    Quote Originally Posted by 100 mph jet boat View Post
    I run the 42x55
    Apr 2012
    Md
    121
    Thanks guys
    bullets, 42x55, adj tabs, 4 x 5000 40c 2s
    What size prop comes on the 31 .?????
    Apr 2011
    tx
    1,284
    Another easy upgrade is the run 4s2p (two 4s parallel). Double the run time and lowers amp pull considerably. Plus the impulse has plenty of room to fit high mah 4s batts in it.
    Apr 2012
    Md
    121
    im with ya, my next set of batterys will be 4s. there out of stock
    Apr 2011
    tx
    1,284
    Try the sky lipos. I've had great luck with them. Better than the gens in my opinion.
