Results 1 to 6 of 6
Thread: Trim Tabs on a cat?
    Aug 2010
    WA
    30
    Default Trim Tabs on a cat?
    Hey i was just wondering if you can out trim tabs on a cat (pro boat mystic).
    Will doing this help the handling of the boat? Or not really help at all?
    Any help would be great!
    Mar 2012
    126
    it probably would help, tho you could try adjusting the propeller strut. I found that if you adjust the strut down, it makes the boat porpoise more; but if you adjust it up, as awkward as it sounds it does in fact make the boat ride flat.
    I've installed a secondary rudder, using it as a trim tab, and a 2nd water pickup. she dances on the water. its really cool.
    Nov 2009
    US
    5,557
    Trim tabs on a cat is trying to help a bad setup. Adjust COG, strut etc first.
    NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE: https://forums.offshoreelectrics.com/...est!&highlight=
    AZ
    8,009
    Four-month-old thread, I'd assume that he's well past the issue.
    Oct 2012
    tx
    99
    Oct 2013
    TX
    1,060
    Bringing the thread back...
    So I assume that tabs only help during the planing time but also a little "bounciness"?
    I have a 32" Rivercat but I run in the choppy waters so I can't really get on it or it gets in the air...
    Would a led weight help up front?
