Results 1 to 9 of 9
Thread: How should I fix this Flex Shaft?
Hybrid View
    May 2010
    312
    Question How should I fix this Flex Shaft?
    Had my Fastech out last time and it quit out on the water, motor revved but no movement.
    After getting it in I found the flex shaft was the culprit
    Here is what is should look like all one solid piece
    here is how it is, the end piece just turns freely and can be pulled off as shown in the picture.
    How do I re-attach it, or do I need to get a replacement?
    The Speeders *PB SW 26 BL *PB Formula FASTech
    The Cruiser *CBM Marlin Cruiser
    The Pool Toys *Proboat Mini-C (x2)
    Mar 2010
    MA
    3,573
    if it was soldered in you can heat with torch and resolder.
    May 2010
    312
    Well I don't have a torch, but will have a new soldering iron (100w) arriving in the next couple days so I will see if I can do something with that.
    Feb 2011
    120
    This just happened to me about 30 min ago. So it's just soldered?
    Real men have shafts.
    May 2010
    312
    Ya I fixed mine by just re-soldering it on..unfortunately when putting it back in the motor was a little mis aligned and I forced it too hard and wrecked the other end..go figure
    So a new drive shaft I will need..just can't get one now as I am not spending any more money on my boats since we just found out we have a baby on the way so priorities have changed... So my fastech is now dry docked for a while lol
    Aug 2011
    oh
    625
    Is that a 4mm flex with the square drive on the end? and if so how long is it I may have one.
    May 2010
    312
    Quote Originally Posted by SirBudman32 View Post
    I'm not sure what size it is, it's the stock shaft for a proboat formula fastech. Maybe someone can chime in that knows.
    Aug 2011
    oh
    625
    I have a piece that is 9 3/4 inchs long that I dont need. If it will work, could send to you.
    Nov 2009
    949
    I use green loctite, bearing retainer, and it works great on the stub shaft, never lost a prop yet,
