Results 1 to 1 of 1
Thread: Supervee 27 with 2030kv Motor
    Aug 2009
    fl
    147
    Default Supervee 27 with 2030kv Motor
    [CANCELLED; I GOT MY ANSWER, THANKS.]
    this is for a sv27 with a 2030 ul-1 motor installed. the esc is the 60 amp aquacraft. so, is the stock 40mm prop better for this setup than the metal grim racer 40x52, or 40X52/3 (whatever the three means....)
    i guess this depends on the pitch, since they're the same diameter?
    thanks!
    steve
