Page 3 of 47 FirstFirst 1234513 ... LastLast
Results 61 to 90 of 1400
Thread: First build... Cheap boat, lots of power
  1. #61
    Aug 2010
    MO
    1,173
    Ok well i have some line i could use. Its 1/8 inch rod. Its strong stuff i got at my hobby store. Could this work or would i need something else?
  2. #62
    7,631
    I think your best bet will be getting the kit that I posted by octura.It was $63 or so and comes with a flex cable,Fine's does not.The only thing you would need is a drive dog and prop.There are some options there as well, IE:Prop shaft size.
  3. #63
    Aug 2010
    MO
    1,173
    For props, i have some from offshore, they are plastic props. They are cheap but all a different color and different pitch. I cant look them up on my phone but if you guys can that would be cool and let me know what size drive dog i need etc. I have the props at my grandpas garage where i was working on this boat. So i found a strut and/or a stinger for about 10 bucks. So im at 18 bucks? Why is the kit a better bet, sorry im a teenage guy that doesnt have much money.. hah
  4. #64
    Aug 2010
    MO
    1,173
    Found this i might need to look at..
    http://www.ebay.com/itm/R-C-Boat-Shi...-/380426153095
    Same thing i think... Would this work?
  5. #65
    7,631
    You're gonna need this http://www.offshoreelectrics.com/pro...od=oct-oc64pkg and a stuffing tube(brass tube) to go along with that e-bay setup.So the flex is another $23
  6. #66
    Aug 2010
    MO
    1,173
    Could i get any of this at my lhs?
  7. #67
    US
    5,557
    Go with a strut like this....................cheap and easy. You will need a flexshaft as well..............dont know the size but I think its 3/16.......either that or 4mm.
    http://www.offshoreelectrics.com/pro...qub7881&cat=76
    Here's where i suggest the drive hole to go..........and where the rudder should be
  8. #68
    Aug 2010
    MO
    1,173
    Ok. Thanks for the picture. Will that rudder/strut i showed earlier work?
  9. #69
    7,631
    I got to learn how to do that with a pic M-a-W.
    I doubt that you'll find any boat stuff except a RTR boat at the LHS.That is the way it is around here anyway.You could check.
    Now you see why that one complete kit is worth it,the SV strut is $22,and still needs stuff,the cable is $23 and you still need a rudder.The kit will for sure all fit together eliminating further issues.Only need a drive dog,best as I can see.
  10. #70
    Aug 2010
    MO
    1,173
    Ok i will save up and get that kit. Hope it works. If any of you find a cheaper kit,c that would be GREAT
  11. #71
    Aug 2010
    MO
    1,173
    The rudder and strut I found email I can buy it now for 20
  12. #72
    7,631
    The only thing with that setup is a serious lack of info.They don't say if it is for a 4mm shaft or 3/16.
  13. #73
    Aug 2010
    MO
    1,173
    I will ask the guy and find out. What should i ask him? Any info i need to ask for?
  14. #74
    7,631
    I did some research and best that I can tell is it is 4mm.My concern was the bushings but it looks as though they would come installed. You can get a 4mm shaft that is stepped down to fit 1/8 props which is probably all you will need.Also probably what you have.
  15. #75
    Aug 2010
    MO
    1,173
    Oh great. Sounds good. So this would work fine?
  16. #76
    7,631
    It should work fine,not what I would do,but fine.But then I just blew $1200 on the last build.
  17. #77
    Aug 2010
    MO
    1,173
    Ya i really dont have 1200 bucks... Hah. I have 1/8 rod so i could use that as i think you just said. I will try finding the props i have.
  18. #78
    7,631
    You will need a flex cable and prop shaft.Not 1/8 rod
    Like this http://www.offshoreelectrics.com/pro...?prod=ose-1085
    Actually not like...THIS is what you will need.
  19. #79
    Aug 2010
    MO
    1,173
    Ok. Could i use rod for mock up?
  20. #80
    Aug 2010
    MO
    1,173
  21. #81
    Aug 2010
    MO
    1,173
    Sounds good. What kind of tube should i get? I will check at my hobby store and see if they have flex tubing because they have a boat section.
  22. #82
    7,631
    Sorry Mason,I'm doing a build/paint job for someone on the side. You should just get your parts and then go from there.You could for now prep the hull.Sand all the old crap off,wetsanding works best for this.Just get it looking smooth for primer.
  23. #83
    7,631
    Quote Originally Posted by masonis1 View Post
    You could ask the dude with the TFL strudder if it is for a 4mm shaft and if it has bushings.If it is as I figure then you'll need a 7/32 brass tube.Is that a bidding thing or just a buy thing on e-bay?
  24. #84
    Aug 2010
    MO
    1,173
    He said he would take 20 for buy it now
  25. #85
    7,631
    Am I correct with the 4mm and bushings?
  26. #86
    Aug 2010
    MO
    1,173
    I dont know yet. I will findout as soon as i can.. i will sand the boat down and clean it up.. also, how can i make a boat more bouyant?
  27. #87
    7,631
    Any foam pool noodle around?
  28. #88
    Aug 2010
    MO
    1,173
    No. I dont go to the pool much, i have the nose of the boat filled with foam tho. What else could i do... Also, can i run a water cooling from the rudder, to the motor, out the motor, to the esc, out the esc, and out the boat?
  29. #89
    7,631
    That is the idea.Only in this order,From rudder to ESC,out ESC to motor,out motor ,out boat.If the nose has foam in it that should do it.
  30. #90
    Aug 2010
    MO
    1,173
    Ok. After i finish putting the electronics in, should i fill the rest of the hull up?
