Looking for that standard size servo that'll give you some major grunt???
I ran across this bad boy.............threw one in my cart too.............
Nearly 300 oz. of torque on 6v!!!!!!!!!!
Not a bad price either..................oh, waterproof too!!
To put this in perspective, the Traxxas 2056 that alot of us run has 80 oz. of Torque. The "beefed up" 2075 has 125 oz.
SPECS:
Curve gear with smooth Double ball bearing (Si-oil)
3 pole strong torque motor with low signal affect and success get CE certification
Rubber fitting case for waterproof
Heavy duty servo case
Middle heat sink
Design by digital signal with 100% fitting square PWS
Automatic measures central ms
ALU 6061 material of metal gear with light C95 material for light and strong
Digital IC (SOP package with 12bits transfer data)
MOS-FET driver (spirited driver able to push over 7A power)
Weight: 54g / 1.84oz
Dimensions: 40.5 x 20 x 37mm / 1.60" x 0.78" x 1.52"
Torque At 4.8V: 18.8kg/cm , 258 oz/in
Torque At 6.0V: 21.2kg/cm , 292 oz/in
Speed At 4.8V: 0.15 sec / 60° at no load
Speed At 6.0V: 0.12 sec / 60° at no load
http://www.hobbyking.com/hobbyking/s...15sec_54g.html
