Results 1 to 7 of 7
Thread: Segad is slow...
Hybrid View
    Dec 2011
    269
    Default Segad is slow...
    Damn you would think that there would be more speed to this thing... handles great and all but my spartan and MC both can lap this thing... any suggestions to get more speed? ive done everything I can... running parralel 3s lipos with the stock 2700k motors and 60 amp esc's...
    Lakeside entertainer
    Aug 2009
    tx
    3,534
    4s or bigger props
    Nov 2009
    US
    5,557
    It wasnt engineered with big speed in mind with those smallish motors. A pair of these on 4s each would get it rockin'!!
    These are 4 pole motors btw: http://www.hobbyking.com/hobbyking/s..._Inrunner.html
    NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE: https://forums.offshoreelectrics.com/...est!&highlight=
    Mar 2012
    NY
    17
    No need to replace motors, go to 4S Lipos and get the venom CNC props or anything but the stock plastic props, you will see a big difference in speed.
    Nov 2009
    Ca
    2,686
    just be sure to get the 32mm props if your gonna run 4s with stock motors. The 36mm props might be pushing the limits of the stock components.
    Apr 2011
    ID
    18
    Quote Originally Posted by forescott View Post
    Forescott is correct. Make sure you are running the 32mm props.
    Paul Susbauer
    Venom Group International
    May 2012
    Az
    190
    So these will run the 4s if you run with the 32mm props ? anyone had success with this setup? Not looking for blinding speed just something fast and still reliable. Stock motors stock ESC's . It seems to run well on 3s with the 36mm aluminum 3 blades. Sanding the bottom of the sponsons seemed to free it up a bit more.
    Don't forget to put your brain in gear before you engage your mouth! Thanks Dad!
