Results 1 to 3 of 3
Thread: hydro talk
    1,453
    Default hydro talk
    tried looking in to the search section but did not find much
    - how do i know which props are lifting type and when to use them
    - i have seen photos of hydros with a negative angle on the strut is this to pick up the rear of the boat- why not use a lifting prop
    - if you had a long strut on the boat would you not need a lifting prop or any angle because it would be easier to lift up because of leverage and less likely to blow over by making the boat feel longer
    Apr 2011
    1,759
    https://forums.offshoreelectrics.com/...ions-somewhere.......
    I don't know the strut angle vs lifting prop, but a lifting prop is less efficient then a normal prop so minimal angle with less effect than a lifting prop would be more efficient.
    1,453
    good find thanks
