Results 1 to 2 of 2
Thread: Correct charging voltage for 1350mAh 3s 11.1V 25C LIPO PACKS
    Jan 2012
    3
    Default Correct charging voltage for 1350mAh 3s 11.1V 25C LIPO PACKS
    I believe I had it set at 0.7 the first time I charged them and it seemed like it took a long time to charge fully,thanks in advance for your input,this is a great forum!
    Apr 2011
    VA
    134
    1c is the normal charge rate for most lipos so I recommend 1.3 amps which should take an hour or less to fully charge depending on how much you run them down.1 hour at that rate will put in 1300 mah.
