My batch of Mini Rio's came in today. I have to say from first glance I'm impressed with the stock boat and the promise of being able to upgrade this boat easily.
Plus there's something to be said about being able to fit this in a suitcase to take on vacation with out an issue with space.
First the prop is plastic, measures 30mm in diameter and sits on a 3mm shaft. Octura 1/8" props will fit but be a little large. A piece of shrink wrap on the shaft or a wrap of tape around the shaft will take up the space.
The Mini Cat Racing USA has the mini hydro props that are carbon filled and fit 3mm props. So there is an abundance of sizes to try out.
The drive lined up to run in surface piercing! Another plus!
As for upgrades the cable is thin for brushless motors. I can't see it lasting a long time under bl power. I will be looking for upgrades for this area. The quickest choice is the Mini Cat Hydro Cable and shaft. The only issue with that is the drive dog. Its not tappered like the stock drive dog, so the mini Cat setup will be an area of large drag if thats not addressed.
I will be trying the stock motor first. I would like to try a 3s pack. Will have to wait and see if the stock electronics are up to the task?
Thats it for now.
