Results 1 to 5 of 5
Thread: Old boat nitro to electric conversion, sub-surface drive
    Jul 2011
    NO
    27
    Default Old boat nitro to electric conversion, sub-surface drive
    My father built a boat back in the 80's some time, and we are looking at converting it to electric now. Below are some pictures of the boat as it sits today after i removed the old hardware. It weights in at about 4,5 kg without that lump of a motor in the pictures. I don't think this boat would look right with surface drive, so i am thinking of keeping it sub-surface, but change the drive line. Maybe do a flex cable and bend it a bit upwards under the hull?
    Since this is a pretty heavy boat and it will be running sub-surface i was wondering if any of you could share some experience on how to proceed. Not looking for big speeds here, but about 30 mph would be nice. I have been trying to find some advice online for props and motor, but seems surface drives are what most talk about now. Am i correct in thinking that Octura X4 props would work sub-surface? I saw some posts mention the 12 series as sub-surface, but i have not found any of those yet.
    As for motor, would a big Leopard be a good choice? One of the 56 series motors on 6 or 8 S? Maybe run 2-4 packs since this boat has plenty of room to spare. I know the recommended RPM's for surface drive, but completely blank on what to aim for on sub-surface.
    Any advice is appreciated as me and the old man would like to have this boat on the water come summer time :)
    US
    5,557
    I run a large 45" boat with the Leopard 4082 1000kv on 6s......hits about 33mph, but its a scaler so its just perfect. I'd go with the 1000 on 4-6s based on your speed desires.
    http://www.offshoreelectrics.com/pro...o-4082&cat=148
    Jul 2011
    NO
    27
    Thanks Make-a-Wake. Are you running it surface or sub? I am playing with the calculator posted in another thread recently that gives advice for setups based on hull type and size, but i guess it gives recommendations for surface. From what i have found out i need to downprop when its sub-surface. Would maybe something in the 40 mm range be a starting point?
    I also see i forgot to post the dimensions i had written down. Hull length is 97 cm, width is 32 cm.
    US
    5,557
    If you went with the 1000kv Leopard which is more than enough to move that hull well, i would start with a 35-37mm prop......... Mine is surface drive and i'm running an x445.
    Here's a vid of it running when i had a Neu 1250kv in it. Small lake, i think I got close to full throttle once at 1:20 mark.
    Jul 2011
    NO
    27
    Very nice boat you have there!
    I have been considering going with surface drive, maybe a stinger, just not sure how it will look since its more of a scale boat look. But maybe it wouldn't be so bad. Would make things a bit easier as well i think.
