Page 1 of 2 12 LastLast
Results 1 to 30 of 33
Thread: Adding a capacitor to the Turnigy Aquastar 120 A speedy
    ca
    6,961
    Default Adding a capacitor to the Turnigy Aquastar 120 A speedy
    My Jersey Skiff has a rather long run between the speedy and the batteries now that I found the correct CG by moving the batts to the back. Even with dedicated cooling to the SC it comes in a little too hot for comfort, so to reduce the ripple current* I'm thinking an additional cap will help . ( *Actually I prefer Ripple Strawberry but that's another story )
    Stripped the batt wires close to the SC and tinned them
    prepped cap; shrink on cap wires keeps it insulated
    soldered on SC wires
    insulated solder joints with shrink & secured with a larger band of shrink
    Nothing new here, just thought someone might be helped by this.
    Tony
    WA
    2,038
    It can never hurt to repeat the good stuff Tony. Not sure why but OSE has boat loads of info, yet so few bother to do a search. They just ask the same questions that have been answered a hundred times.
    John
    Change is the one Constant
    ca
    6,961
    Quote Originally Posted by m4a1usr View Post
    John
    John, Sad but true. I actually thought this would be too redundant to post.
    Jan 2010
    205
    Just finished doing that on my old C80 Cuda ... part of the reason I still have the old girl :)
    I really like the anti spark setups. Saved a lot of equipment watching my caps like a hawk and installing anti-spark on everything
    Oct 2008
    376
    Tony,
    Would you mind informing all on the benefits of adding capacitors? When needed. Capacitor bank vs single. (I know some info its on the main site, but here would be good as well)
    Any words of caution....)
    Sean
    ca
    6,961
    Quote Originally Posted by sanyijr View Post
    Tony,
    Sean
    Sean,
    I'm not qualified from the point of electrical theory to go any deeper into the issue than to say that adding capacitors, in the end result, makes the SC run cooler in certain cases. I was just one of the sheep that followed along when the "add capacitor fad" started some time ago. Those better educated in this subject may chime in.
    Jan 2010
    205
    Helps with heat dissipation (more/larger the caps ... better heat transfer), helps the esc handle spikes, and smooths out the flow of 'juice' through the esc.
    Wont give you greater performance past the specs of the esc, but will give you a greater measure of safety.
    ca
    6,961
    Quote Originally Posted by jimi911 View Post
    Perfectly worded. In the case of my Jersey Skiff, which due to it's design and irregular running attitude vents and unvents the prop to a large degree, the extra cap should smooth out the spikes and ripple current when this occurs, especially with my extended battery-to-SC wires.
    Jan 2010
    205
    For those with the larger Castle HV escs, there is a cap bay that is pretty handy and easy to install. I just put one on my HV110 for a bit of extra protection. Adds some length to the setup, but its good piece of mind. This unit also has an anti-spark setup I added, which is nice on the HV rigs.
    ca
    6,961
    Oct 2008
    376
    Tony,
    so to followup on my question... Why did you only add 1 capacitor to your Aquastar? Wouldn't 2 be better? Or 4? Is there a general rule of thumb of what size/number capacitor to X cells, or amps anticipated? Or % of ESC power used to esc rating? Does that question make sense?
    Sean
    Oct 2008
    9,488
    Thumbs up
    Not at all Tony..
    I thank God for posts like yours and the great info for us to use..
    ca
    6,961
    Tony,
    Sean
    Sean, I'm "electronic theory challanged" so here's my "rule of thumb" :
    1] : Measure thumb :
    2] : Find capacitor of similar dimensions :
    3] : count thumbs
    4] : Install thusly : # thumbs = # capacitors ( if you're one of those people that are "all thumbs", buy extra capacitors)
    Seriously, I hope someone with more grasp of this answers your question. It's been discussed & posted before on OSE.
    Enjoy,
    Tony
    Oct 2008
    376
    Tony,
    I appreciate your literal interpretation..... But your math worries me a bit
    But I do see you are using 25V caps. Can you (or anyone since Tony will use a differnet rule of thirds or something creative....Not that there is anyting wrong with that) give any advice on the Voltage capacity on the caps? I assume Capacitor voltage should never be less than the total battery voltage.... Is that a safe bet?
    ma
    8,693
    John
    I really have to work on going a better job on categorizing helpful tips.
    Steven Vaccaro
    Jan 2010
    205
    There are several options for cap size and setup
    Some go with one large cap with a high voltage
    Advantage - Takes up less space, cheap, easy to solder, and you can use some seriously hi voltage caps if you want.
    Disadvantage - There's only one cap to blow and, in theory less warning.
    Some go with multiple caps
    Advantage - Easier to keep on eye out for swelling ... normally one goes first (swelling, discoloration, odd heat characteristics ... burns when u pee ... wait thats something else).
    Disadvantage - Pain to solder, more expensive if you start buying pre-made 'bays'.
    When choosing a cap size I normally just look at the esc I am using and match it up. For example, my 110HV is running 60v caps, so I added bay with 4 more. Not a bad rule is to look at your voltage and double it (ex. I run 30v caps on my 4s setups). Or you can just solder a huge 400v cap on there and go nuts ... I've seen that to! As long as you have a cap that matches the voltage demands you should be ok.
    Oct 2008
    376
    That makes pretty good sense. (Except the burning part).....
    ca
    6,961
    OK, I'll bite ; as long as we're discussing cap values, what uF (micro-fedorka?) value should be considered ?
    Jan 2010
    205
    Lol ... that's when my info ends :)
    Dec 2009
    on
    2,187
    Value isn't as important as voltage, as you add more caps in par. the values add up.
    A mix of small and larger would actually work the best, smaller caps can absorb higher frequency ripple easier than a larger cap.
    Cap quality is another important factor, cheap ones can't stand the heat like a good one can.
    Cheap caps are the curse/blessing of vintage tube amp repair! My most common repair job, PS caps!
    Aug 2011
    oh
    625
    Ok here is a quick question. I have a SV -27 with stock esc in it and just got some Rubycon (35 vdc. 1000 uf ) caps, now should I add one or two? Thanks
    Jul 2011
    67
    Simple Explanation:
    http://www.satcure-focus.com/tutor/page6.htm
    Coffee break is over everyone back on thier heads.
    Dec 2009
    on
    2,187
    Stock one is 470 I believe, adding another 1000 to that would be ample, giving about 1500mF.
    Thats the old version esc, not sure of the value on the newer one but another 1000 would be good considering the capabilities of the esc. As long as your batteries can deliver the current.
    ca
    6,961
    Default Tested with Cap installed
    Ran the JS with the additional cap. SC was WAAY cooler. Know that this is not a totally controlled scientific experiment, but it works for me
    Oct 2008
    376
    Tony, as in when my wife says : "I bought this outfit "WAY" on sale."? Or do you mean Much cooler.
    I will have to give that a try......
    US
    5,557
    I've added caps to my T120's when running 2000+ kv motors...............works well!
    ca
    6,961
    Just bumped into this. Still doesn't give actual values for uF (micro fedorkas) but sheds some more light
    http://www.teamnovak.com/tech_info/p...power_caps.htm
    Jun 2008
    GA
    2,318
    Novak also makes one called the Glitch Buster. Plugs into radio receiver to prevent radio glitching caused from high amp setups.
    http://www3.towerhobbies.com/cgi-bin...?&I=LXNRE0&P=7
    http://www3.towerhobbies.com/cgi-bin...?&I=LXYAN4&P=7
    ca
    6,961
    Quote Originally Posted by detox View Post
    Makes sense. Easiy enough to make also.
    Jun 2011
    ny
    152
    ok so heres a quickie im thinking you can but someone knows more than me
    1 we know we can run 2 batts either parallel or in series
    2 if we run them parellel 2 batts with 5000 mah at say 6s are now 10000 mah but stay at 6s or 22.2 v ,yes or no ?
    so if # 2 is yes then if i have say 2 caps 25v and 500 uf each the 25v will not double it will stay 25v or does it double raising to 50v and does the uf stay at 500 or does that double to 1000 uf? and if it does double then could you use this new cap bank for a 12s or 44.4v setup ? or would they both blow up quickly lol ?
