Results 1 to 24 of 24
Thread: Im happy with my MC...
    Dec 2011
    269
    Default Im happy with my MC...
    Dude my MC kills my UL-1.... turns way better and is just a way funner boat to run... My ul1 is faster but handles like crap.....
    Lakeside entertainer
    On
    7,279
    Its a great boat, but you do know the ul1 is only set up to turn to the right.
    Dec 2011
    269
    yes, but I still have to slow down to avoid rolling... It handles a little better with the stock prop but that just kills the speed...
    AZ
    8,010
    Cool
    If you have to slow the UL-1 down to keep from rolling, then something is not right. Either you are trying to turn too tightly, the water is too rough, or the setup is wrong. Guys in our club are turning fine at 50 mph. Cats/tunnels are the most maneuverable of R/C race boats, and the MC in particular is a lot of fun to drive. But the two boats are designed for completely different applications, and some folks prefre one over the other. AquaCraft decided to cater to both kinds.
    Dec 2011
    269
    Apr 2011
    VA
    134
    Is that all stock with stock prop?
    Also what batts are you using and did you change bullet size to 5.5mm?
    Dec 2009
    on
    2,187
    Looks kinda slow to me, and running real wet. Where is the CG and how is the strut set, what prop.
    Dec 2011
    269
    its all stock... 4200mah 2s Grim lipos... took it out of the box and threw it in the water... bench tested the motor and esc... thats all...
    Dec 2011
    269
    The prop is a Grim 42x55...
    Dec 2011
    269
    Quote Originally Posted by siberianhusky View Post
    The prop is a Grim 42x55... I dont know how to tell the CG all I did was set the batts in the middle, and what does "running real wet" mean??? the strut is adjusted a hair down to seat the back end from the prop upgrade... and thats all... why does my boat look slow to you??? remmember that its all stock... what gives? what do I need to do to make it faster without switching electronics???
    Nov 2008
    WI
    662
    Robde
    What is the biggest differance between what you see in my run here.. same prop.. same batts..
    http://www.youtube.com/watch?v=1ucNx...xH6s-VnrgekQc_
    and your run video?
    RC boating is a great hobby.. Great to discover and learn.. I hope you are having fun!
    Grim
    Dec 2009
    on
    2,187
    Set the cg between 27 and 30% of the total boat length forwards from the transom, Run the strut with no angle at all. Raise the strut until the nose of the boat becomes to light and threatens to blow over backwards, now go down just a bit. Just move it a little bit, 1/16 of an inch max per try, until you find the sweet spot for the CG and and prop. You might not be able to get it right with the strut, this means you need to adjust the CG a little bit and start over with the strut adjustment.
    You will be amazed at what happens when the boat begins to dance across the water, yours is staying glued to the water the whole length of the sponson pretty much. Takes a lot of power to push a boat like that. Get it adjusted and you will see what it can really do.
    I'm actually running a motor with a lower kv than the stock one but a bigger prop, it's a Proboat Geico 1500kv motor. Another one of the "spec" class motors puts out about the same power as the stock motor but runs at a lower rpm, the increase in torque lets me run a bigger prop but at a slower rpm. Killer acceleration and hook up out of he turns, about the same top speed maybe a touch slower on top, Lap times are about the exact same, less cavitation at take off as well.
    The only real change in mine is I filled the huge dips running the length of both sponsons, known as "blueprinting" the bottom and squared up all the edges on the bottom so the are nice and sharp not rounded.
    I put a SV27 rudder on mine with a water pickup, it's a direct bolt on replacement, I kept the sponson pickup so the esc and motor each have their own cooling circuit. Installed a pair of outlets in the side of the boat so I can see the water coming out. Ran the original outlet hose as another inlet hose from the rudder.
    You'll really enjoy it even more once you get it dialed in, It's like you discovered a hidden gear!
    Dec 2011
    269
    cool thanks man... should i get a smaller prop with the 2030kv motor that my boat came with? im running the Grim 42x55... and I see what you meen about the small adjustments, I ran today and its getting better... now to work on the CG... Thanks again Husky!!!
    Dec 2011
    269
    Quote Originally Posted by Grimracer View Post
    Robde
    and your run video?
    Grim
    HAHAAA obviously yours is running way faster!!! question for you my friend... My MC came in the box with the same motor as my UL-1, the 2030kv, IDK why it did but it did... im running the Grim 42x55 prop... should I downsize the prop or what? Thanks bro, Love the AQ boats!!!
    Apr 2011
    312
    Keep prop and everything else , just get the cog correct I beleive is what grim is trying to tell you!!
    I'm married with children, you can't scare me!
  16. #16
    Nov 2008
    WI
    662
    Default hum
    hum.. a 2030.. that would be a first.. did you buy it new? did you buy it at a hobbyshop?.
    In any case the 2030 proved to be to much for the boat "IF" you have the boat set to tight.
    If it was me.. I would change to the 1800.
    Grim
  17. #17
    Mar 2009
    MI
    6,453
    How do you know it is the UL-1 motor?
  18. #18
    Nov 2008
    WI
    662
    Quote Originally Posted by rc2266 View Post
    The idea was.. The run was planned and methodical. I knew just how tight I wanted the boat to turn and I only used full throttle when needed. No willie nillie.
    I determined a length of straightaway and I never run into a corner wide open.
    You can talk setups all day long but learning to really drive the boat.. is way more valuable than any setup.
    Watch the video again. Pay attention to my boat. Not the speed so much but were it is lap after lap on the water. If you want to turn left that’s fine.. just plan it!
    There is a good chance your boat is just as fast as this one, scotts'. Scott is the throttle man for the full size Motley Crew!
    But before I sent the boat to him it had to run just like mine!
    Grim
  19. #19
    Dec 2009
    on
    2,187
    I should have mentioned that my testing and setup is done around a course, this way you have something to really compare against. LOL I only turn left if I have to.
    Just some plastic bottles anchored with bricks works great and can be picked up easily for a course.
    Racing against yourself and the clock is harder sometimes than racing against 5 other boats! Easy to beat other people eventually, way harder to beat yourself!
  20. #20
    Dec 2011
    269
    Thanks for the info guys!
  21. #21
    Dec 2011
    269
    I bought it off EBAY new in the box...
    Grim
  22. #22
    Dec 2011
    269
    I have 2 UL-1s...
    Quote Originally Posted by Rumdog View Post
  23. #23
    Nov 2008
    WI
    662
    Hum.. that is suspicious.
    The motor that comes in the UL1 is marked 2030KV on the end bell.. The SV27R and MC use the 1800KV.. again marked on the end bell... and what ever else we might have up our sleeve.
    I have a sneaky suspicion somebody switched the motor before the boat went up for sale.
    Grim
  24. #24
    Dec 2009
    on
    2,187
    Hmmm something new on the way I assume? Exciting!
    Be cool if it was a slightly bigger mono, love my sv but a few inches longer and a little more stability in race water would be awesome!
