Results 1 to 17 of 17
Thread: Can I run 4S batteries on a stock boat?
    Dec 2011
    Fl
    29
    Default Can I run 4S batteries on a stock boat?
    I've been running my boat with 2S2P 5300mAh 40C batteries. I've read a couple of posts where they where running 4S batteries on stock boats. Will the motor and ESC handle those batteries? Should I upgrade the connectors before running those batteries? I'm currently using Dean connectors.
    Thanks.
    Oct 2011
    DE
    332
    What motor and ESC are u running and what boat? I am running well putting together a 21 whip with UL1 running 2S2P with 45 C batteries opps (2s2s sorry )
    Nov 2009
    US
    5,557
    So you've been running only 2s...........7.4 volts? Or have you been running TWO 2s packs in series for 4s or 14.8v?
    NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE: https://forums.offshoreelectrics.com/...est!&highlight=
    Oct 2011
    DE
    332
    I think he's saying its 4s but I'm just guessing
    Nov 2009
    US
    5,557
    You're probably right..........two 2s batts and he's thinking thats 2s2p.
    If i'm taking him correctly, i think he has heard of folks running 4s batts..........probably 4s2p...........like a couple of 4s 3500mah's or so in parallel.
    Oct 2011
    DE
    332
    well I'm not really sure how u guys put that either lol I just put it like that too so maybe I'm wrong to lol I'm running the UL1 setup and it runs 2 - 2S so I'm guessing its 2s 2s
    Nov 2009
    US
    5,557
    Nope, you are running 4s plain and simple.
    S = series
    P = Parallel
    4s = 4 cells in series. Doesnt matter if its two 2 cells connected together pos. to neg. for series, its still 4s total voltage.
    4s2p as I mentioned earlier, is 4 cells in series(one 4s pack, or two 2s packs) paralled with another 4s pack for 4s2p, If two 4s batts were connected in series(pos to neg) then it would be 8s1p...........but the 1p is not stated in this case........only in the case of 2p, 3p etc........
    Oct 2011
    DE
    332
    Yes it is , just have to change the deans plug to 5.5 bullets. Sorry about stealing a little of ur post
    Nov 2009
    US
    5,557
    Not my thread...........if only we could get Mr Back-lash to respond.
    Dec 2011
    Fl
    29
    Sorry for the delay guys. Got stuck at work. I'm running the stock motor and ESC in my Impulse 31. I'm running 2 2S 5300mAh 40C batteries. I'm new to RC boats so I'm a little lost. The reason I put 2S2P in the first post, is because that's what's on the battery. When I was reading the manual that came with the boat it mentions it's 4S compatible. The guy at the LHS told me to run the 2S batteries, so I was wondering if I can run 2 4S batteries (more power = more speed, right.). So I'm assuming I'd have to reprogram the ESC to handle the extra voltage, but will the motor and ESC take it. Also, would I have to upgrade the connectors to 5.5 bullet connectors instead of Deans (was planning on doing this at some point anyway). Thanks for the replies.
    Oct 2011
    DE
    332
    Still not sure what ur running stock is all kinds of things stock
    Apr 2011
    TX
    86
    What you are running is correct and what is recommended by proboat. You are running 4s right now per what you have stated. If you use 2 4s battery on the stock setup, you would be running 8s and your esc would last a few seconds. What you are running (4s) is great for this boat and I would recommend that you prop the boat up a bit (X642, M445) to get some more speed (right around 40 MPH).
    Dec 2011
    Fl
    29
    Thank you very much for the info. I now understand what you are talking about, and what proboat is saying in their manual. I will stick with these batteries for now, until I upgrade motor & ESC. I was looking at props already, so that's great info. So much to learn...
    Sep 2010
    nj
    4,289
    Hi,
    You can run two 4s packs for more run time,
    And it may run a little better with the added weight and more amps in that boat,
    But the 4s packs need to be setups in parallel so it just 4s 14.8volts and your MAH will double for more run time.
    And check your temps to make sure you are just running warm and have good water flow coming out.
    And you should use 5.5 bullet for your connectors on your stock setup,
    You will need two of these for parallel setup,https://forums.offshoreelectrics.com/...let-connectors
    Nov 2009
    US
    5,557
    Quote Originally Posted by Back-lash View Post
    Your batteries are more than sufficient..........as suggested for more speed, play with props..........doesnt it come with like a prather 215 stock?
  16. #16
    Apr 2011
    TX
    86
    If you setup your esc to run packs parallel as lenny stated, then yes you can run 2 4s packs. I have done this and felt the boat was just to heavy and I really didnt like how it performed (just my 2 cents). I like running 4s (2 2s) because you still get a decent run time 10 min (5000 mah pack) and it gives you time to check temps when you bring the boat in to change batteries.
  17. #17
    Dec 2011
    Fl
    29
    After doing a little more research, I've decided to stay with the 2 2s packs. My charger will handle up to 3s packs only (onyx 245). I'm going to start trying out some props.
