Originally Posted by
Mattwarner
Ok so as the title suggests i reallly struggled getting the cooling hose on from inside the hull (37" Genesis Cat) , I read tips about long nosed pliers and washing up soap but i simply couldnt do it and got increasingly frustrated!
I then had a brainwave which i thought i would share!
1. get yourselves a length of stiff wire, I used 2mm servo pushrod which worked perfectly
2. Poke the wire through from the outside of the hull inwards with enough left on the outside to hold onto.
3. Soap up the end of the cooling hose and thread it onto the end of the wire which will guide it straight onto the nipple, with a bit of force the hose will slip into place.
Backwash with some fresh water to remove the soap and DONE!
Hey Matt, You been spyin' on me or what ? That's exactly how I've done it for years. 'Cept I use a 4-40 servo rod with the threaded end in the silicone tubing; kind'a grips the tubing. I just put some spit into the tubing; works best after eating some McFries ! Good find and thanks for sharing
