theres a few new ones
http://www.hobbyking.com/hobbyking/s...or_1000kv.html
5692s!
5692s!
You beat me to it=) These are actually TP power motors which seem to be a slightly more refined version of the leopard motor, countersunk case screws and the like. For the money I don't think the is a better 6kw motor I have seen anywhere. Get in quick before the price goes up=P
6BOOST
6boost Turbo Manifolds, Australia's number 1 turbo kit specialist and manufacturer
That thing is a beast for sure.--10 s on a 5692 wow you could power a 12ft fishing boat with that..
The prices are awesome on these!
A couple of things:
1: At 1000 RPM/V this is not a 10S Motor. 40K. Your going to kill something. Controller most likely.
2: At 3.6"x2.2" this is smaller than a Nue 2215 and a Lehner 3060. I doubt this is as powerful as they say.
3: 8S yes or 9S in a hot set-up with a 452 or Bigger if the Motor can handle it. ( Doubt it though) I run a 2215 and a 3060 with a 457 or Larger and
the Motors are Physically bigger.
4: For $80 bucks give it a try.
They are the exact same thing as a leopard 5692, which people have data logged on eagle tree to over 7kw and many people have run 35-37krpm on those, the TP motors are supposedly a more refined version of the exact same motor with better bearings and build quality, if they are I don't know but they do have nice countersunk case screws and look to be better quality. Do a search for what people are running on a leopard 5692 and I'm sure you'll find plenty that are driving a 57mm prop. I'll let you know, I have 4 of them coming=)
6BOOST
if it says it can take 10s than I bet it could!
They have 5 to choose from....
Ordered a 5682 1700kv today (along with a 56 mm cooling jacket and a 8 mm to 3/16" coupler from OSE). We'll see what happens?
I have no idea, haha. I usually run hulls in the 30" range with 3674's, 4074's and 4082's like everybody else but I suspect a 5682 with a ~50 mm prop will just be way too much to handle for those kind of hulls. When I find the weapon (hull) of choice I'll begin on the slow 'n easy side with a M180 esc and 6s2p (5000 mah 25c) and Prather 225. To be honest - I bought it right away 'cause Hobby King usually add 15-20% on their prices once the sales go up.......or I'm just paranoid with a short memory
I'd really like to try those 3996's too, when they release something suitable for 6s. It just sucks to buy new LiPo's for one type of motor. I think I have 4 of 2s, 4 of 3s, 4 of 4s and 2 of 6s. It has to stop somewhere!
what about the fightercat 41" hull?
The specs on the 1000kv 5692 say 40 volts............10s = 42 fully charged..............its a perfect 8s motor. They make a 780kv which would be great for 10s.
http://www.hobbyking.com/hobbyking/s...tor_780kv.html
Why can't you run your 6s packs on one? make it 12s. Or even better yet run 10s and make 2 pairs of packs with your 6 and 4s and you can charge one set while your driving the other. I have run the 3994 on 12s and its a monster, motor, batt and esc temps all under 100F after a full set of packs (2x6s/5ah) and will drive a 50+mm prop, the X447 I had on it did almost nothing and the 450/3 still didn't get it over 105F. Make sure you get a decent size hull if you try it tho, its is way too much for anything but saw use in anything under 40" imo.
6BOOST
I believe you. I had a feeling that thing was monster motor My packs are all different mAh and C's and as well as not having to buy new packs I'd like to not having to buy HV-esc's. I'm cheap, at least right now. I really like the M180 and for the price it's unbeatable (imho). So, 6s at the very most. For now.
Something in the 40" range - check!
12s speedy is less than the 180: http://www.hobbyking.com/hobbyking/s...oat%5FESC.html
Keep in mind with twice the voltage you need half the amps. But I'm sure you motor and esc combination will work nicely together. Shame your packs aren't compatible tho.
6BOOST
Yep, I know. I think the 80A constant rating is a bit on the low side for these big motors. I guess those HV-esc's were meant to work together with low kv 3674-4074 territory, but that's just a guess. If Im getting let's say 4000 watts out of a 5692 1000 kv on 8s - Im pulling 135A = magic smoke.
About the LiPos. Yeah, you kinda outgrow, learn new things etc. and in the end you're just buried with stuff you have no use for.
I still do run a cat with twin KB 3674 2700kv on 3s although I'm changing direction to HV and low kv. It hauls (and whips up a rooster tail of doom!) 84 km/h = 52 mph. This is on the fifth run the same day and I hope I can tune another couple of mph out of it.
I think your getting the wrong idea about HV, I wouldn't call 8s HV, I'd call 10-12s HV. On 10s that esc if it meets it's rated power is capable of 3000w continuous and 6000w peak, allowing head room say 2500 and 5000, on 12s it's 3500 and 7000, so allowing headroom 3000 continuous and 6000 peak. Realistically on 12s if you were conservative on the prop and it is capable of what they rate it to it should run a 5692, I wouldn't personally try it, my intention was more for the 880kv 3994 motor on 12s which is 4000w peak. I'm gonna buy 2 and check them out, could make a cheap effective 12s controller, might be cactus on first use. Only one way to find out=)
6BOOST
The 5682 arrived to day. It's one huge S.O.B! Where do you guys find motor mounts?
someone has a thread in the special services, he might be able to fab one for you, or go to FC.
Here next to a brushed 400, for that important OMFG-effect
Motor mount: http://www.etamiya.com/shop/silver-a...-90018942.html
It is approx. 3.5" wide. I remove the side plates & make my own.
Well.... can you tell if it's a 4 pole or 6pole motor??
You might be able to see the magnet segments if you remove the front cover.
Thats up to you.
I would assume that means 6- pole, but you never know.
