Results 1 to 4 of 4
Thread: So are these as fast as....
    NJ
    1,322
    Question So are these as fast as....
    Hi guy's are these as fast as the china mini offshore worrier?
    Anyone compaire the two?
    THANKS
    WWW.PPRSLOTS.COM
    Aug 2010
    uk
    2,887
    The Mini Mono is a great looking boat that ive never ran. I do have extensive experience with the Warrior in stock & modded form. Ive seen a review on the Mini Mono that said they thought it was doing around 25mph. A stock Warrior will do 35-36mph. The Mini Mono only has a 2200kv outrunner motor & 20amp esc. The warrior has an inrunner 2445 3000kv & 30amp esc, Both run 3s. I dont think their are many if any Mini size monos that will match the Warrior on speed out of the box, In modded form you can achieve around 50mph for not much money. Testimony to a good hull design as well. Martin.
    Oct 2008
    CO
    9,488
    Who has the Warrior? And how big is it?
    Thanks..
    Dec 2011
    fl
    32
    I put a 35 amp water cooled esc and added an octura 432. Sharpened the fins and raised the trim tabs up. I think this little minimo would give the warrior a run for it's money!!!!!!!! At a stand still hit the throttle and the boat jumps out of the water. Crazy fast!!!!!!!!
