I have a question if anyone knows. I ordered Fuller's hardware last week. I sent the order in for the cat hardware. Ray, called and said the Hydro hardware is the one to use for turning right. This set-up came w/ 1 1/2" down strut that sits off of the transom like a Hydro setup.
1. Where should I mount the strut ? Right at the bottom of the boat ? Do I need to offset it a bit to make up for the prop ?
.The rudder is offset and is 1 1/2 inch from the center of the mount to the hinge. Rudder itself is 2 3/4" from the bottom of the rudder mount.The rudder looks like it will sit on top of the strut and allow (the strut)adjustment up. This way only allows 3/4" to 1" away from the prop. The rudder is about 3 inches away from the prop if I mount it to the side of the strut.
2. Which way of mounting the rudder is better ?
Vortex 22 hydro ammo 36-50
Vortex Cyber Storm 33 P spec Mono AC 36-56
PT SS-45 Q-hydro Neu 1527/1Y
