Page 12 of 12 FirstFirst ... 2101112
Results 331 to 358 of 358
Thread: Fixing the BJ26 Handling Issues
  1. #331
    Nov 2009
    Ca
    2,686
    Sounds perfect to me. You're not getting much cavitation at all.
  2. #332
    Aug 2010
    wi
    1,461
    I'll mess with some step once spring comes
  3. #333
    Aug 2010
    wi
    1,461
    I am final putting my bj back together, it was all in a box, trying a miss g flex shaft.
  4. #334
    Aug 2010
    wi
    1,461
    Is it spring yet? I can't rember winter being this long!
  5. #335
    Feb 2011
    tx
    97
    prop nut,when you moved the fins to the top hole,i take it you drilled a new hole for the lower screw,and then covered up the old old?i will have more questions about all this once i tear into it.but figured i would start with the fins
  6. #336
    Dec 2007
    MO
    62
    Quote Originally Posted by dirty View Post
    Dirty, yes you will need to fill the old holes and drill two new ones. I used epoxy to fill the old holes. Please read through the first few posts in this tread for more info on all the mods done to the boat.
  7. #337
    Feb 2011
    tx
    97
    oh ok,i thought you used the existing top holes and drilled 2 more on top of that.I will go back through the posts
  8. #338
    Dec 2007
    MO
    62
    Dirty, that is exactly what I did, I guess it just didn't sound that way when I wrote it, lol!
  9. #339
    Aug 2010
    wi
    1,461
    What kind of speeds should you expect out of the stock setup, boat was bouncing on top of the small waves, but it took a while to get on plane. I hit around 26.9 mph with 7 cell 4200 traxxas and a 3 blade prop, I am going to try the same setup witht the stock prop, I have lipos but one has a bad cell, I think.
  10. #340
    Aug 2010
    wi
    1,461
    went back out, still not really smooth, a lot of jumping around, ran the stock prop. With stock prop it got on to plan a lot easier. The first pack I ran was a new set of seven cell. Got 27 mph even, then I put the lipos in 30.7 mph.
  11. #341
    Jul 2009
    5,669
  12. #342
    Aug 2010
    wi
    1,461
    Quote Originally Posted by tiqueman View Post
    , detongued and tip cup.
    whats that? I need to try a clam day before I do anything major.
  13. #343
    Jul 2009
    5,669
    Detongue is removing the area close to the hub that kinda swings forward and then back to the tip. Easiest way to explain it, look at a M445 and an X445. The "M" series props come detongued from the factory. Cupping is very slightly bending the tips back and or the traling edge of the blade. That kinda describes it, its a bit more involved and easy to mess up if your not careful.
  14. #344
    Aug 2010
    wi
    1,461
    Had my boat out today, it went well until I took it to the other side of the pond and ran out of room, the front has a small crack along the seam, but I did not spilt it open, I'm sure it will get a few more war wounds before summers done.
    http://www.youtube.com/user/112racin.../0/fejMrqO-fI8
  15. #345
    Jul 2009
    5,669
    Quote Originally Posted by roadrashracing View Post
    That hurts. Yeah, they dont run well on land. Get her patched up and back out there
  16. #346
    Aug 2010
    wi
    1,461
    I don't even think it needs to be packed right now, just a hair l;ine crack
  17. #347
    Apr 2011
    MA
    58
    I'd atleast throw alittle epoxy behind it so it dosent get any bigger
  18. #348
    Aug 2010
    wi
    1,461
    Is it possible for the bec to burn up in the speed control? I used my boat a few weeks ago and it worked fine, I go to use it today and nothing, no power to the speed control. the wire is hooked up. I try it tonight and as soon as I put a rx back to the reciver the boat works fine.
  19. #349
    Jul 2009
    5,669
  20. #350
    Aug 2010
    wi
    1,461
    I guess I just use a battery pack, not worth taking it all apart.
  21. #351
    Jul 2009
    5,669
  22. #352
    Aug 2010
    wi
    1,461
    true
  23. #353
    Aug 2010
    wi
    1,461
    I just cut the switch off and twisted the wires together... simple n easy
    thanks powers up fine now
  24. #354
    Apr 2011
    id
    23
    by far my boat is running better with out turn fins
  25. #355
    Sep 2014
    AL
    8
    Thanks for the info, Bumping this, and subscribing as a newb.
    ProBoat Blackjack 26, Octora X642 prop (Sharpened and balanced by OSE), Removed Battery Trays & Styrofoam to Add pool noodles making battery slots in the bottom of the sponsons and float whole boat full of water, stock out-drive, 2-(5000MaH, 2S, 30C's)
  26. #356
    Jan 2015
    ca
    25
    Does anybody know where to buy a detounged x642? Thanks
  27. #357
    Jun 2008
    NY
    581
    Chris Hoffman aka dasboata can make one for you. Send him a PM and tell him Tom Jerzak sent you. He does great work!
    https://forums.offshoreelectrics.com/...?5485-dasboata
    Tom
  28. #358
    Jan 2015
    ca
    25
    Tfhanks tonstoys2...I will do that......
