Results 1 to 8 of 8
Thread: 60 mph setup???
    Jan 2011
    OK
    375
    Default 60 mph setup???
    Could someone tell me what a good 60 mph setup would be? motor,batts,prop?
    Jan 2011
    WA
    218
    I can't say for sure about 60mph but I've gotten close with my setup...at 58.2mph. I'm running a leopard 4074 1700kv with a seating 180a esc with a bec. Batteries are two zippy 3cell 5000mha 45c using 5.5 bullets and a sharpened and balanced m645 prop.
    " Do you really need anouther boat "
    YEP!
    Nov 2009
    US
    5,557
    Sounds like Stephavee has a great setup..................one thing you could do further is use a 4082 1800kv on 6s that will have a few more rpms and can swing more prop.......although the m645 Stephavee runs is a monster already......may not be able to take much more in a 31" hull. You could possibly sneak an x646 on it.
    Speed calc says 66 mph with this setup at 85% efficiency.........
    NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE: https://forums.offshoreelectrics.com/...est!&highlight=
    Jan 2011
    WA
    218
    Yeah I could run a 4080 motor and bigger prop but runtimes would suffer. The m645 is about the biggest prop I would like to run on this boat because of torque roll and prop walk issues. I think if I cut some weight and get my tune right 60mph is possible with my setup but will take some tweaking.
    YEP!
    May 2015
    MN
    14
    I want a fast setup too - what about the stock 1800kv motor with 5.5 bullet connections hooked up to two 3s 5000mah lipos with Traxxas connectors - with an Octura x646/3 prop
    Would that work alright? The boat has updated dual cooling lines
    May 2015
    MN
    14
    Okay so what size should I get then? Is the 3 blade prop better than the 2 blade?
    Oct 2013
    la
    8,722
    Quote Originally Posted by MrSTUDofRC View Post
    Personally I wouldn't run a 3 blade on that. It will load things even more. You definitely need a motor and Esc upgrade if you plan on going that fast.
    Oct 2008
    CO
    9,476
    Quote Originally Posted by kfxguy View Post
    I'm with Travis on this
    and on the stock motor running 6s I'm not sure I would run much bigger than a 42mm prop to start with
    could cook that motor and esc
    Jesus is King .......NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
