A BIG thanks!
A BIG thanks!
Steven Vaccaro
Steven hows it looking for getting photos of this I gotta know pretty soon so I can button up last few boats for the calendar.
OSE GIFTING ELF
HAPPY HOLIDAYS!!
All Right, the site's back up. Now go test the 10s rigger and don't forget the video!!
I have to work every day for a few more weeks. but I'm moving forward. I got some more packs, so I have a second set now.
Steven Vaccaro
So... THAT's what OSEphil, the master builder looks like huh?
I can't wait to see the sponsons. I hope they're yellow!
Steve how's the build going hope it is almost done can't wait to see it Thanks Chris g
Can't wait to see this crazy beast run!
Do or do not, there is no try!!!!!
Aeromarine Titan 29 H&M Hawaii Kai III Proboat Stiletto ML Boatworks PS295 (No.8)
We only got a few hours on it at the lake before winter and ice forming. Hope to be able to get more time on it around the end of march.
Steven Vaccaro
What is the measurment of the sponsons from the inside of the tub to the inside of the sponson?
I am reworking a old 70s wingding and would be intrested to see what your with is.
the wing ding is 32" long and moving the sponsons out and foward will put it at about 33"-34"
this will be a 6s set up for now.
I will post a new thread soon on this project, will call it WingDing resurrection.
Finally got to get out and play with something we wanted to today.
Still needs a bunch of tuning. But still Lots of fun.
Steven Vaccaro
What prop did you use?
Bunch of abc props, 2318 2 blade and up.
Steven Vaccaro
Nice work!
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
Still dragging its tail. Seems once i get the tail out of the water it hops. Any ideas?
Steven Vaccaro
i am watching this thread steven as i have a sport hydro hopping also......some say put weight in rear others say change prop etc....let us know if u get it fixed....
Lightly cup the hopping prop near the outer edge of the blade.
We only ran one 2 5s packs in series. Next time out I'll run the 4 packs to make 10s2p. The weight and balance will completing change, so I'll be interested to see what happens then.
Steven Vaccaro
That change in weight could do it alone.
Steve;
drop the strut aprox. 1/8" and keep it level.
With the ABC line of props they lift alot. keep the strut level.
if the back end still hops, you will have to actually adjust the strut positive by just a hair
to remove the hopping.
If you dont like the way the boat is running after that, then switch over to a 14 or 16 series Octura prop. (still keeping the strut level)
Steve , I use 457 /460 / m 62x80 . 3060/8t. 10s/2p . 2 4s packs in front and 2 6s packs behind those, 5000 mah. Cheers ,Jay.
nice boat steve ..also using a 2028.. what prop for 14s?? :)
jason
Steven Vaccaro
14S is far too much for the CC2028, that's 40,000 rpm unloaded while the factory says not to exceed 30,000 rpm. Plus 40,000 is SAW territory, not for sport running or oval racing. If you want that kind of voltage, it's better to use a motor with a lower Kv. BTW you can't get NAMBA or IMPBA insurance for a 14S boat....
thankyou , any updates on this 10s boat ?
Jason
