this was fee at first but after just running in for 20 to 30 seconds on the bench it tightened up?
It is never a good idea to run an FE boat motor for more than a second or so out of the water. There is no good reason to (unless you just want to hear it run) and a lot of reasons not to do so. As above, it can overheat with no water to cool it - an electric motor run without load gets hot fast!). Too, running at full- or near-fulll throttle will cause the motor to run at too high an rpm, risking both motor and cable damage. Don't do it!
