Results 1 to 17 of 17
Thread: what my boat hopping on stright run
    May 2009
    NY
    94
    Default what my boat hopping on stright run
    Hi all i just ran a 28" balsa wood boat that i build from Peells plan .the boat hop a lot when running straight . see video http://youtu.be/3R6GPvO3puY here the set up i am using In runner Brushless Motor B3656 KV2600
    Aluminum adjustable stinger drive with 4mm cable set
    Zipps kit 50 Amp Brushless Motor Controller
    2S 7.4V 4200 mah lipo battery pack
    Aug 2010
    uk
    2,887
    Move the cg foward to around 30% of the hull length in from the transom, it looks like you also have the stinger up to much at the prop end. Set the stinger level.
    May 2009
    NY
    94
    Quote Originally Posted by martin View Post
    Yes your right the stringer is high but their no adj for so i make something to level it and what cg ?.I have the motor at at 3/4 of boat starting from transom to front
    Aug 2010
    uk
    2,887
    Cg is centre of gravity, the hull should balance at around 30% of its length. Example if the hull is 28" long then 30% would be 8.4", so the boat should balance 8.4" in from the transom (rear of hull). You can then fine tune the balance from their but 30% is a good starting point.
    Feb 2009
    ar
    878
    Does this boat have trims tabs? Tabs can help prevent porpoising like that.
    Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
    Aug 2009
    tx
    3,534
    Cog, trim tabs and put your strut angle down a bit just my opinion
    Jul 2011
    CA
    1,091
    Pictures????
    Tommy Levescy sponsored by: RCJuice.com, Rawspeed, Scorpion Precision Performance, TC Racing, Triton RC, Oxidean Marine and Cencal Hobbies.
    Current Namba 1mile record holder: Pltd sport hydro 1:19:72 P-sport hydro 1:14:31
    May 2009
    NY
    94
    no trim tab on it i may try and see it that help
    May 2009
    NY
    94
    boat has battery move up front it still came out of water at half speed .will try next week with the stinger drive angle down a bit and with Feigao 540L "Long" Brushless 540 11L 2,326 RPM / Volt 5mm Shaft motor.to run on two 2S 7.4V 4200 mah lipo pack wire in series
    May 2009
    NY
    94
    what size you think i need and how far out off back of boat .me thing 1 1/2" off back and 1 1/16 from bottom of boat
    Aug 2009
    tx
    3,534
    I thInk the bottom of the strut should be flush with the bottom of the sponsons
    Feb 2009
    ar
    878
    Quote Originally Posted by kennyrach View Post
    I'd go with 2" wide by 1-1/2 to 2" long tabs. Put them 1/16" (2mm) above the bottom of the hull (not flush). Adjust if necessary. Should tame it right down.
    Aug 2009
    tx
    3,534
    sun i was talking about the strut i started with mine flush and level and angled down just a little when my apparition was nosing up and bouncing
    Feb 2009
    ar
    878
    Yep, I'd try adjusting the strut down first. But if that won't fix it, tabs will.
    May 2009
    NY
    94
    Thank all for the info i will try all and see thank
  16. #16
    Apr 2012
    lo
    29
    sorry new to boating but when u say adjust the strut which bit on the boat do u mean same with the tabs
    cheers
  17. #17
    May 2009
    NY
    94
    What i found on my boat is strut angle down will bring boat bow down and strut angle up will bring bow up ,the tabs help the boat run even .You can try and see it this help
