Results 1 to 7 of 7
Thread: Metal prop upgrade?
    Aug 2011
    10
    Default Metal prop upgrade?
    What is a good metal prop for the joysway offshore warrior?
    Aug 2010
    uk
    2,887
    On the stock esc you have to be carefull what you go to, an Octura x432 works well but dont go any bigger. If you use plastic props you can use x435 that Joysway offer as an upgrade prop themselves. I use a different motor & esc & run Octura x632 & get around 50mph. Martin.
    Aug 2010
    uk
    2,887
    These are with Octura x632 detongued metal prop but with outrunner motor & upgraded 60amp esc on 3s 60c lipo.
    http://www.youtube.com/watch?v=AuDAKRRtLA0
    http://www.youtube.com/watch?v=TMuXLiVSl3I
    Aug 2011
    10
    I just got mine and it is stock I am running a 45c thunderpower. So the octura will work?
    Apr 2012
    lo
    29
    is this the right one for a offshore warror 2
    http://www.ebay.co.uk/itm/OCTURA-X43...#ht_1519wt_906
    Aug 2011
    10
    will the octura x432 fit on the stock offshore warrior flex cable?
    Aug 2009
    tx
    3,534
    i use a sb 435 with a 50 amp esc ans a 450 2500kv outrunner on 4s and shes quick
