Page 1 of 13 12311 ... LastLast
Results 1 to 30 of 375
Thread: Shawn's Shocker
    7,631
    Default Shawn's Shocker
    Well here we go,just off one rebuild thread to today.Happy happy Joy joy:I recieved my Carbon fiber Shocker 950 from Fightercat.
    The packaging was awesome and not so much as a nick in her.I must say,the edges and flats of the sponsons are great.This is nice as I just did a ton of work to my MG sponsons.So far I have the 110mm stingers,200 amp Swordfish's and a pair of TP 1810 kv motors.I have everthing else ordered(I think).L&R 3/16 flex cables from Jeff Wohlt & tubes,A 5" dual pickup rudder and all the little pieces.She is to be run on 4's and 5's(6's SAW?) with 445 props ordered.
    I don't know how my time will work out for this as I'm pretty busy at work and this is my first build thread and first build in a long time.So any hints or suggestions right off the bat.Oh yeah,did I mention this thing is superlight for it's size.
    Jul 2009
    5,669
    Oct 2011
    That thing is almost to pretty to paint. I vote for the carbon look
    Jul 2009
    5,669
    Quote Originally Posted by Hinkelberry View Post
    definitely, a few decals and call it done. HydroJerry did a nice job on his CF Daytona. Geico theme on CF, looks really nice and clean
    7,631
    You got it.Fightercat Diamondplate Logos and perhaps a name(its my thing).Other than that a whole can of U-pol clear 1.you got me hooked Scott.
    Anyone know what would happen if I sanded the seam a little first.
    Jul 2009
    5,669
    7,631
    Yup thats what I figured,I guess that I could add a little epoxy to smooth the seam.Sometimes I get fussy about these things.It'll be later anyway.
    Jul 2009
    5,669
    mmm, I dunno about adding epoxy. You may be asking for trouble. Not seeing it Im not ure how bad it is, but id probably scuff it, get it smooth and build it up w/ clear. until you cant feel it. clear it with a couple coats, wait a few days and sand it. if its smooth to touch, clear it again and your done. If not, repeat the process. Give it a couple more coats, wet sand it, if its good final clear it.
    Jul 2011
    Va
    152
    If you intend to race the boat I would think twice about leaving it that color . If you flip it or it just quits on you during a heat it's going to be a hard boat for other drivers to pick up . I agree it will look awesome , but not a good choice for racing .Just my two cents .
    Sep 2011
    MO
    12
    Cool Build. Keep us updated!
    7,631
    Quote Originally Posted by highflyerbill View Post
    Yeah I agree with ya but so far there is no racing in my neck of the woods.I once had a black outrigger with a little chrome fishscale on it and nobody I was running with at that time liked it.Thanks for the input.
    7,631
    Quote Originally Posted by tiqueman View Post
    Sounds like good thinkin,time consuming but good.I can't do anything else on it till I get my flex's from Jeff Wohlt anyway.
    7,631
    Just thinkin of things I've missed and a question arises,When you drill out the stingers do you use a Speedmaster bushing or the lead teflon Octura ones.
    Jul 2009
    5,669
    did you not get 3/16 stingers????? I usually make my own bushings if Im gunna go the speedmaster type or the Octura. Both work well. I have found if I have to drilla 4mm stinger out, Ill often use homemade bushings since you can make a smaller outter lip and not have to drill the stinger as deep.
    7,631
    Oh yeah,I did indeed.I guess I got a little confused with all the e-mails the other day,drilling had to do with the square drives and such and actually has nothing to do with my 3/16 stingers.My bad.Probably overthinking.
    7,631
    Here's a little update.I've been wet sanding the join seam on the hull.You can see in pic 1 the small lip/edge on it before it is sanded
    That is only rough sanded to knock it down.
    And I have waterproofed the Swordfish' and made some CF sheet for assorted stuff.
    Oct 2008
    9,488
    What about some see through colors??
    or lay the graphics in the carbon and paint the rest a sweet color??
    7,631
    Yeah,I'm still playing with ideas and thats rolling around in there as well.
    7,631
    Well after much sanding and patience in waiting for the clear to dry the seam is gone,OK, not gone but nice and smooth.Ready for some clear.
    7,631
    I recieved the rudder and miscelaneous items in the mail so here is a mock up.May get some things done on this this weekend.Flexshafts should be here this next week so I can probably drill stinger holes after another layer of carbon is layed up.These hulls are really light/thin so I would feel better with extra CF as I've seen my MG's blowovers and although I can try not to let it,inevitably it will.I may even add bulkheads,not sure yet.
    Note that the rudder bracket fills the transom extension nicely.I may back that up with aluminum inside as I did on the MG repair.
    Jul 2009
    5,669
    7,631
    While I'm out and about today thought I might pick up my servo.I've been thinking of one of the ones I use for my trail trucks.They aren't real fast but torquey.277 oz in.What do you guys run with these big rudders?
    7,631
    The reason I ask is during the last run on the "MG",my rudder needed adjusted on the servo spline.I assume it jumped a gear,so I am thinking a metal gear but not sure how much torque is required?
    Aug 2011
    UK
    487
    I've gone for a 9.0kg/cm but mine is a low profile as I am running a push/pull set up and need the clearance. I think a lot use the hitec high torque metal geared one.
    Jul 2009
    5,669
    I usually run the low pro hitecs in my cats. I just recently had one fail but I think it was bc of previous water intrusion. I put a new one in that boat so we will see.
    7,631
    I guess it would be best to run a low profile servo.That way I won't have to put as much bend in the rod, if any.Here's the mounts and my CF.I couldn't find any that was infused with chrome or diamond plate so went with just plain.
    7,631
    Quote Originally Posted by Mattwarner View Post
    So are you running the Spektrum one that I am looking at?I should be able to at least water resist it with some Conformal coating,just in case.
    7,631
    Got the rudder backing plate in.Its threaded so no nuts to fuss with.Also made larger plates out of thin CF to support the doublers.They will be epoxied all around.
    7,631
    Well the build got moving along with the 2 weekends we've had here in Wetcouver.I got the motor mounts placed and epoxied,doublers epoxied,stuffing tubes in and stingers mounted.Now this hull is getting stiffened up.A little weighty as well but it should still stay under 10lbs ready to rip.I can't decide wether to place the ESC's in the sponsons by the motors or on the tunnel.It's really tempting to pull the end bells and solder the ESC wires direct,Anybody have an opinion on this?
    My battery trays and servo mount should arrive this week.Paint soon.
    Jan 2010
    2,498
    i was told its better t have the batts in the sponsons to help even the weight..
