Originally Posted by
roadrashracing
so a higher c rating might give you a mph or 2, new batteries are coming in spring
When you get good cells... Try an Octura X645... There are several prop options that will get you closer to 40, but I hate to recommend them unless people are willing to upgrade all their connectors, and also are willing to push their equipment over it's "rated" limits...
If you upgrade all your connectors to 5.5mm minimum (you CAN live with the deans, though they will get warm), you can push some pretty decent props behind this boat with the stock power system. The X645 is a really good starting point.
Darin E. Jordan - Renton, WA
