Results 1 to 10 of 10
Thread: Dual battery charger
    Sep 2007
    502
    Default Dual battery charger
    I was wondering what would be a good charger for Nimh and Nicd. Im looking for 1 that can charge 5 or 6 min and 7 or 8+ max cells. My price range is around a 100-120. Im looking for a charger that can charge 2 batt's at the same time. Any links are
    Failure is the First step to SUCCESS
    Nj
    4,735
    With out question the AstroFlight 112D. It can charge up to 40 cells @ once. It is right around 120 bucks new. I used one for my high end Nimh and always got a great charge and my cells lasted quite a while.
    112D link
    Sep 2007
    502
    I couldnt get any info from the link but do u have to use a Y harness on it?
    Thank you for the link so far that sounds pretty good i have somin that im looking at that can take a lot of volts. That will be nice to have that extra cablabilaty. Once again thanks thats prably going to be my choice. Do u have any more info on the charger?
    Wa
    5,905
    yes you will have to have the y harness. look for a good used one they are going cheap because no one uses them any more.
    Jim
    Billy Graham
    Sep 2007
    502
    Wa
    5,905
    112DX
    FEATURES: Charges 1 cell to 40 cell NiCd or NiMH battery packs
    Charges any cell capacity from 50mAh to 10,000mAh
    Charge current adjusts from 50mA to 8A
    Charge Mode has Auto-Peak and 10 hour time limit
    Discharges 1 to 40 cell NiCd or NiMH battery packs
    Discharges at 1.25A and has Auto-Turn Off
    Digital Display of Charging amps from 50mA to 8A
    Digital Display of NiCd Voltage from 500mV to 40V
    Digital Display of Charge/Discharge time, hrs, min. and sec.
    Digital Display of total mAh of charge into or out of battery
    Digital Display of maximum voltage reached (voltage peak)
    Charger works with any 12V automobile or truck battery
    Charger works with Astro Model 120, 13.8V Power Supply
    Reverse Polarity protection on both input and output
    REQUIRES: 12V Power Supply
    SPECS: Input Voltage: 12V DC
    Battery Types, # cells:
    1-40 Nickel-Cadmium cells (1.2- 48V NiCd)
    1-40 Nickel-Metal Hydride cells (1.2- 48V NiMH)
    Adjustable Charge Current: 0.05-8.0A (Single Knob)
    Discharge Current: 1.25A
    Display type: 2 Line (amps, volts, Time, and amp hrs)
    Battery Connector: 2 pin Zero Loss type
    Power Input Connectors: Alligator
    Case Size: 2.5" x 5" x 6.5" (63mm x 127mm x 165mm)
    Battery Lead Length: 9" (229mm)
    Input Lead Length: 36" (910mm)
    You could also use the 110D or 110DX
    AstroFlight Charger Model 110D
    Digital Peak Charger will charge 1 to 18 cells
    Will charge Nickle Metal Hydride Cells
    Slow charge 1 to 18 cells at 0-1 Amp
    Fast Charge 1 to 18 cells 1-5 Amp
    Both are great chargers
    Jim
    Billy Graham
    82
    It is also very simple to just make one yourself - and a lot cheaper. Look at picture of one to see how to do it so it connects the battery packs in series. Only costs are the connectors, a bit of wire, and about 10 minutes of your time. I believe there is information in the tips and info section of this site on how to do this.
    Greg
    Sep 2007
    502
    When i get better at soldering ill do that. ya i think there is a button on the main page that has it. I just dont remember where i saw it but i know what u are talking about. Thanks for the info Jim and Greg.
    82
    If you go to the online store click first on "batteries and chargers", then on "charge adapters and harnesses". There are a couple there. If you do decide to make your own you can find info on soldering Deans plugs and charging multiple packs at once in "wiring and electronics tips and info" on this site. Hope this helps.
    Greg
    Sep 2007
    502
    Thank you Gregs
