The hull on my mystic, which I think is made the same way as my impulse (yet to get into water), is that they glue the top and bottoms together, when it hits something, it splits along this glue line. It's good to reinforce the join between the deck and the hull with glass and resin. Carbon fibre ..... to get the real benefit it is usually moulded and set under heat .... you don't get the "carbon" benefits with just resin at room temperature, for just strength (tear resistance) kevlar would have been a better option. Also inject some expanding foam in the bow when finished, add almost no weight, makes it VERY rigid, and will stop it sinking. They put a bit in now from the factory, but not enough to fill the gaps (seems more for bouyancy than to add structural regigidity and strength.
I also have the bug, mystic (needs cracks fixed after touching the jetty), Impulse 31 (out of the box .... has broken dog pin for the prop), and stilleto is on it's way courtesy of USPS, god bless USPS for those of us who don't live the USA.
Looking at bailer options for my boats now.
Proboat Mystic, Proboat Impulse 31, Aquacraft Supervee 27, Aquacraft Atlantic tug
Hello from Australia.
