Originally Posted by
G Doggett
Thanks for the info Darin.
The packs will most likely be Thunder Power SVX from Andrew at Fast Electrics, but I presume the wiring configuration is the same.
I will make up a wiring harness as per your plan, but do any manufacturers have a ready made harness ?
I'm sure many guys would want to charge pairs in series with the balancer operating.
A single 4S pack is the way to go for simplicity, but in some set ups 2 X 2S is all that will fit.
Graham.
Graham... I wouldn't assume that the TP packs have the same tap arrangement... You'll have to consult their diagrams and work that out... I don't know of anyone that sells a ready-made hardness like this... but it would be nice... My 1/10th scale and my smaller P-Mono hull both need to run saddled and series'd 2S packs to fit... The other option is to just charge them separately , but this takes a lot of time...
Darin E. Jordan - Renton, WA
