Results 1 to 4 of 4
Thread: extra cooling
    Oct 2008
    ky
    240
    Default extra cooling
    hi , i wanted to add a 2nd water pick up? will the sv 1 rudder work on the svr? or should i add 2nd pick up tube on the right side of the stinger????
    Dec 2009
    on
    2,187
    The rudders are interchangable between the aquacraft boats, I'm using an older SV rudder on my Motley for the water pickup, put the motley rudder on my SV because I have 2 under hull pickups installed.
    You can also use the UL-1 rudder which is black and has a water pickup. I'll probably buy one for the Crew at some point so the hardware matches again.
    Oct 2008
    ky
    240
    good deal :) sounds like ul1 rudder is the one. thks
    Oct 2008
    ky
    240
    WOW already got the rudder!! super fast shipping
