I need to install a new flex shaft in my Mystic 29. I looked at the upgraded Miss Geico shafts that OE sells (I had read that the Mystic uses the same flex shaft as the MG), but the shaft stub is only 2.25" long. I just replaced the bushings in my Mystic strut and found that the stock drive shaft stub (2.5") just reaches into the front shaft bushing. The shorter stub on OE's upgraded shaft will not ride in the front bushing. This doesn't seem like the right situation....
Do I need to order a standard pre-fabbed .150-3/16 flex shaft and cut it to length, or can I use the standard Miss Geico shaft set, or OE's shaft set with the shortened stub? (I have an assembled Miss Geico shaft on the way from Kintec.) I'd prefer to order from OE.
I need to get this sorted out and have parts in hand before next weekend!
Thanks as always for the helpful advice,
desmobob
