Here's a brief overview of how the Traxxas Spartan upgrade path goes:
- run the stock motor/esc on 6s (or even 4s) until it burns up, if it doesn't catch the boat on fire and sink it (which has actually happened!)
http://www.youtube.com/watch?v=Ztr4yJxYAz4
- Then replace the motor and speed control with something of better quality (hopefully the Castle combo provided under warranty by Traxxas), run that faster and faster until you stuff the boat into a wave, in which case, this may happen
https://forums.offshoreelectrics.com/...axxas-Spartan&
- then replace the hull (might as well replace the cheap hardware while you're at it) with a hull made of fibreglass that can withstand some speed, then...
You'll pretty much have replaced the whole boat...you will still have the original radio though.
Just sayin...this is how things seem to go with this boat.
Here's a far better starting point:
(Cheaper too)
