i noticed mine was slower as well once when i took it out with the 078 wire, and found my drive strut loosened, I'm thinking even though the wire drive is much thinner i'n diameter , it's stiffer , less flexible than a flex cable, so there was more stress/ tension on the strut, causing it to loosen easier and i'n my case it ran wet, but this is just my experience, i set it to neutral or 4 mm from the bottom most part if the hull for now and I'm gonna try it hopefully this weekend. One more thing, i also had one of jeffs couplers on there which is 4 set screws, now that may be fine for the stock batts , but i ordered the octura type coupler that pinches the wire as you tighten the 2 nuts, your able to get a tighter fit, because you can only tighten the setscrews so much before they strip or you break 4 wrenches.... Lol! But @ Indiana, just make sure you use a decent amount of blue/ medium loctite on the motor Wire drive coupler to eliminate any question that it's slipping. And if you inspect the wire after your run (when you grease it) you'll se evidence if it slipping (i did on mine) but it was still fine to use... Good luck and keep us posted! Sorry for the long post.....
Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
