Results 1 to 7 of 7
Thread: mystic 29 hatch
    Apr 2011
    de
    5
    Default mystic 29 hatch
    hi all this is my first post been a member a while but always found the info i needed this is a great website. but i have yet to see a defiant answer about the thickness of the hatch as i know people had problems with the geico hatch breaking so question is is the mystic 29s hatch any thicker? i know it has flotation now but not sure about the thickness could someone please clear this up for me thanks john
    Aug 2011
    il
    36
    I've had mine for a couple of weeks now. I don't own the mg so I can't compare them. The hatch to me is a non-issue in my opinion. It doesn't seem at all flimsy if that's your concern.
    Jun 2010
    147
    Pro-Boat support is your best source to ask about the thickness of the hatch.
    I had the Miss Geico, flipped it many times at speed and it never cracked.
    Aug 2010
    wi
    1,461
    Are your hatchs fiberglass? I seen a mystic today and it had a plastic hatch.
    9,402
    If you run in cold water it will crack eventually. From what I have seen they are the same thickness & material.
    Jun 2010
    147
    My Miss Geico had a fiberglass hatch.
    Sep 2011
    169
    Mine already has a small crack just ahead of where the grab loops are in the rear. I built up the area a bit with some J.B. Weld as I had to mix up a batch to re-attach one of those little grab loops... it pulled out of the hatch. This winter, when I blueprint the hull, I'll also add a layer of 'glass to the inside of the hatch.
    Take it easy,
    desmobob
