I have been running a Titan 29" with 5S2P Zippy LiPo 5000mAh.
I've been using and external BEC and added a water pump for continuous cooling but last week due high temperature of water and air I was able to burn the Lepard 4074 2000Kv. My fault was to run for more than 2 minutes continuosly without checking the temperatures with an X440/3 prop.
The Seaking 180A, that I've been running, was burnt too.
So, I have ordered this new stuff.
Anybody knows this 180A Seaking? It has a label 180A-R, what doest that mean?
This is the motor and I like the back plate where the cable exits and the holes to let some air to cool the winds, it's different from my previous 4074.
Then I would suggest to the other owner of the Seaking 180A ESC to seal this spot, in my burnt ESC some water passed that spot and I know it from the little corrosion I found inside.
On the other side there is some kind of stuck rubber, this stuff is from the factory.
Uploaded with ImageShack.us
