Results 1 to 2 of 2
Thread: Routing Dual 2.4 GHz antenna leads...
    Sep 2011
    15
    Default Routing Dual 2.4 GHz antenna leads...
    What is the preferred way to route dual Receiver antenna leads (Spektrum MR 200/3000)? Does each one exit a different hull location? I don't think they should share the same antenna tube...or should they? A pic of an installation would be great!
    Aug 2010
    uk
    2,887
    Take 1 up the external tube & lay the other one along the inside of the hull.
