Results 1 to 5 of 5
Thread: Advice please on the Stiletto..
    Sep 2011
    UK
    33
    Default Advice please on the Stiletto..
    Hi,Iam awaiting the delivery of my Stilleto,after reading some of the threads on here I think its not a case of out of the box and into the warter,
    so just a few questions
    Whats the best size lipos ?
    Do I need to grease the Flexishaft if so what type of grease ?
    Is all the electrics waterproof ?
    Any advice would be most wellcome,
    Thanks..
    PS cant you tell Iam new to RC boats and allso new to this forum..
    Jul 2011
    Mi
    65
    Read Darin's race prep thread, all the info you need is in there, do his outboard mod, I use 2x thunder power 5000mah 2s 45c lipo's and am very happy with them
    Tom
    UK
    742
    I'm no expert but lipos, I would go with 5000mah or bigger and the highest c rating you can afford. I use from 25c-40c with good results. Also look at doing the upgrades Darin suggested in the race prep thread although I'm still using the stock liner. Also I would recommend changing the stock deans connectors for something better, I use ec5 connectors also I have changed the motor connectors for 4mm ones. That's about all I have done apart from change the esc fir a turnigy 120a marine one (much smoother throttle curve) and she runs like a dream.
    Sep 2011
    UK
    33
    Thanks, will do
    Sep 2011
    UK
    33
    Brillient guys looks like I have a bit of reading to do.
