I am not being cruel, just brutally honest. You may not want to hear it. A $40 motor and a $70 ESC, an aluminum prop and who knows what strut depth? You have discovered one of the traps of cheap parts. That setup with quality parts should work okay for two minutes, although it is still on the pretty hot side. What is the water temp? Is it really cooling well? We often have to run milder setups in the summer to avoid overheating.
The motor is now ruined, throw it away before you are tempted to use it again! When a motor gets too hot (particularly a cheap one) the magnets are permanently damaged. The motor efficiency goes to pot and you will ruin the ESC if you continue to run it. The Kv on that motor was too high for 6S anyway, you'll be better served with a Kv around 1400 - much easier on the ESC, cells and motor. A higher quality motor will be much better, you won't have to buy it twice like you did with the first one. Good luck and let us know if we can help more.
