Hi all,
just a quick question on solder joints...
If a solder joint is not up to standard e.g "a cold solder joint"
but it still arms the ESC and the boat runs
Will it affect the performance or will it just fail when the temps get up abit?
I soldered the motor and ESC with 5.5 bullets when I was learning to solder and everything runs ok, tho I'm not sure
if I'm getting max performance out of the boat...
so do you guys think its worth re-doing the solder joints now i'm abit better at it?
Thanks Tone
