Results 1 to 15 of 15
Thread: Flex Cable Crucible
    Sep 2009
    TX
    368
    Default Flex Cable Crucible
    Here’s how I tin the ends of my flex cables: Purchased an iron pipe cap plug, ground the threads off, clamped the square end in a vise, added chunks of 95% Tin/5% Antimony Plumber’s Solder, heated with a Propane Torch, submerged the rosin coated cable ends into the molten solder. Works like a Champ!!!
    See DaPic . . . .
    Dec 2009
    on
    2,187
    Great idea! I haven't thought of a solder pot in years! I've been using my mig welder for a while on cables now, takes about 2 seconds and works great as well.
    Sep 2009
    TX
    368
    Must be nice! I don’t even have a place to store a welder, even if I could afford one.
    Jan 2012
    WI
    7
    This is the neatest idea to come "out of the blue" that I've seen! I've struggled with tinning drive cable ends for years and never thought of this great "old school" solution.
    ma
    8,694
    Its a neat idea.
    have you tried just a soldering iron? I use a weller 80 on upto and including .187 cable with no issues what so ever. The weller 80 is marketed to the stained glass market and holds a ton of heat.
    Steven Vaccaro
    Jul 2011
    UK
    1,021
    Quote Originally Posted by Steven Vaccaro View Post
    Its a neat idea.
    I also use the Weller 80. It's great!
    Everything that has a beginning, has an End
    Aug 2010
    uk
    2,887
    [QUOTE=Steven Vaccaro;387219]Its a neat idea.
    have you tried just a soldering iron? I use a weller 80 on upto and including .187 cable with no issues what so ever. The weller 80 is marketed to the stained glass market and holds a ton of heat.[/QUOTE
    Do you find the Weller 80 good for bullet plugs as well, i was looking at getting one myself.
    Jul 2011
    UK
    1,021
    [QUOTE=martin;387526]
    Its a neat idea.
    I use the weller 80 watt with 5.5 and 6mm bullets all the time including silver solder. It does the job every time.
    Aug 2011
    oh
    625
    I got one from harbor freight 180 watt and does them with no problem. And for only 12 dollars, cant go wrong
    ma
    8,694
    Its a neat idea.
    Yes they work quite well on the plugs also. the iron is large so it takes some getting used to.
    Steven Vaccaro
    Jan 2009
    GR
    162
    H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
    MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
    BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
    Dec 2011
    Fl
    693
    So is silver solder best for tinning flex cables? Flux needed?
    Aug 2008
    BH
    340
    Hi Guy's ,
    That Soldering Unit Pot has an Austtralian Power Plug on it , I thought we were the only ones using it. ???
    Brad
    Oz
    Roy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!
    Nov 2007
    6,927
    Do the Aussies use 250V or 110V power mains?
    Mini Cat Racing USA
    www.minicatracingusa.com
    Aug 2008
    BH
    340
    Hi Salir ,
    We use 240V .....
    Brad
    Oz
