I started this quite a while back. Being busy with life and building boats, hatches, etc. for others, I havent had time to do anything much for myself lately. But, I finally finished the build part anyway. Paints next, once I get her all tweaked out.
I built this boat for a new class we are running at our club called STD. or Stock Twin Drive. Basically any LSO set up, but times 2. Currently we have 3 HOTR twins running, mine (until now), RayR and RCKong. I just wanted to mix up the equation and see if the Geico hull would correct some of the issues we are having w/ the HOTR. Seems it has. After a short run yesterday, forgetting to tighten the set screws on the pull pull steering out on the rudder tillers, and missing the water connection between the motor and the exit on the side of the boat (last minute water outlet seal on the motor cooling jacket and just plain forgot) nearly flooding the hull I got most of the bugs worked out of it on its 2nd half, maiden voyage. Still getting a little water in it and Ive got to move the COG a tad forward. I feel in race conditions shes gunna blow over. All in all, I couldnt be more pleased....
Set up is T-120s, Proboat 1500KV motors and cut down 447s L and R 4S1P per side
http://www.youtube.com/watch?v=MpoqJ8Xqvwg
