all was good but for some reason it started to make loud noise until it stopped it i had to make my little cousin to go get my boat and hear is the problem if any one knows good fix let me know thank you all
Welcome to the nightmare.
This is fairly common.
The best option is to get either a .187 flex cable or .078 wire drive from Jeff Wohlt.
The .187 cable will require removing the teflon liner for it to fit the stuffing tube.
I have made several runs on a .187 cable with good success, and just recently installed the .078 wire drive and only have a couple runs on it, but I think it is going to work well also.
The stuffing tube can be replaced with a Traxxas OEM, or pick up some 1/4" brass tubing from the hobby shop and make your own.
Kevin
where can i get some stuffing tube online if you can post a link also do i just put .187 cable in the stuffing tube or how do i do it
Ose store. Have a look around there and use the search button here.
Huh? You are on OSE. Scroll to the bottom of the main forum page. You'll see it there.
Yep, Traxxas has it all worked out: a "Castle" motor, a rebadged esc and there was something else......"oh **it we forgot the flex cable!". And the beat goes on. I find it interesting that many members here and ""there" refer to the success of their Spartans; ignoring
the fact that their heavily modified Spartan is no longer a Traxxas product. At that point the boat becomes the product of the owners ingenuity, tenacity, creativity and talent, not Traxxas. Hence, my boats name is Albatross and supported by products from OSE,
, Kintec, Leopard, many others and the input of members here.
Click on the big OSE banner at the top of every page. Its always there and never changes. Go to the driveline section and click on flex cables/teflon tube part. Scroll down untill you see the replacement cable for your boat. If thats out of stock, find another flex of the same size, and cut and solder your own. OSE has thier own brand as well as Hughey if theyre in stock. Kintec sells flexes too. Might as well learn how to do something.
www.wohltsrcboats.com
thats his web site ,was on there yesterday....
Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
Jeff's store was closed for a few weeks while he took some time off, I think he was supposed to re-open Sept 1.
http://www.rcraceboat.com/
Kevin
Oh gothca Kevin my bad....
also am i gona need that plastic tube ? or just install it in that coper one without it? if i get that .187 from Jeff's store ?
If you go with the .187 cable you won't need the teflon liner, the larger diameter cable won't fit with the liner installed. Just keep it greased up good.
If you go with the .078 wire drive, then you should put in a new piece of liner.
Kevin
i need need that .078 also how do i mount the flex cable to shaft ? do i use glue or something? if so what kind where can i get it ?
i just got coper tube from traxxas and i need stock flex now any one has one?
I need to get a .078 wire drive for a 3/16 prop from Jeff Wohlt. Does anyone know how to reach him? Thanks!! Rob
Fighter cat has them in stock for less than $15
http://fightercatracing.com/index.ph...mart&Itemid=56
You have to sign in to see the prices
When you know it all.......you never will learn anything new
You can try that or try www.wohltsrcboats.com....
i just called one of the site and they have one in stock the original traxxas spartan flex and shaft and they said they are recall they been defective and now traxxas make new once
i need help hear i got original flex cable and it came out from shaft does any one knows what glue to use or welder
Most shafts that are bonded are done with Loctite 603, A few use Loctite 638 that has a slightly stronger bond but is not oil tolerant.
Just buy a .187" cable from OSE and be done with it..
