Results 1 to 16 of 16
Thread: Am I missing anything?
    Jan 2011
    PA
    547
    Default First boat
    Hey guys, just ordered my first boat (Miss Geico) after getting out of crawling.
    Here's a list of parts I have also bought. Is there anything else you'd suggest? Tips/tricks with this hull?
    SeaKing 180A ESC
    SeaKing programming card
    Castle BEC
    x642 prop S&B
    8mm bullet connectors
    10awg wire
    Marine grease
    Nano Tech 2s 5000mah 45/90c (run in series)
    I have been into crawlers forever and was into 50mph short course trucks for about a year. My goal with this boat (being my first) is to be pretty reliable and run low to mid 40's. Let me know how this set up sounds and please let me know if there is ANYTHING I may need.
    Thanks!
    Jan 2011
    PA
    547
    Am I going to need an upgraded flex cable? If so, what do you recommend?
    Id just run what you have selected. It sounds like a good setup. See if the flex is holding up. Ose sells upgraded ones that also have a shorter stub on the end. This helps with a slight binding issue the stock ones sometimes have with the back of the strut as it joins the stuffing tube.
    You may want a offset rudder bracket mount too.
    Jan 2011
    PA
    547
    Thanks for the info!
    I will not be racing this boat, from my understanding the offset rudder just helps in racing because it allows better turning but only in one direction?
    If I do need one, which would you suggest?
    Thanks again for the help and sorry for the newb questions.
    Jun 2011
    SD
    287
    also helps with ther wawawa I finally went to the offset I dont race just like to go fast and it does help
    Jan 2011
    PA
    547
    Quote Originally Posted by skyhighdiver View Post
    Cool which one do you have and how's the steering?
    Jul 2011
    85
    Quote Originally Posted by Gimp View Post
    Some great info in this thread:
    https://forums.offshoreelectrics.com/...s-thing-can-do!
    Jan 2011
    PA
    547
    Quote Originally Posted by PapaGriz View Post
    Yea I've read that thread. But he doesn't mention what bracket he used.
    Is the bracket all I need? Just bolts in place of the old in line one?
    Thanks again!
    Jul 2011
    85
    Thanks again!
    I wish I could offer some advice, but I'm just learning here myself.
    Jul 2011
    85
    Based on this post:
    Quote Originally Posted by JPriami View Post
    I found the boat runs better with strut up. I'm going to have to cut some more off the back trailing edge and relocate the mounting holes for the kintec offset rudder slightly more forward to trim the rest off. Prop clears it now it's just close. I want good clearance.
    2nd water pickup was able to be raised about 1/2 from first mounting condition and still works well with less drag.
    Going to try the castle 1518 motor next.
    and a search I'd bet he is using this offset rudder bracket.
    http://www.kintecracing.com/Miss_Geico_Upgrades.html
    Yes it's a kintec offset rudder. You can find them at KintecRacing.com. It's a bolt on deal and easy to do.
    And lately I've been running the strut down level with bottom of sponsons. Also the angle is level with them. Seems to work ok there. COG between 8.5 to 9" from back of the sponsons not the overhang transom where the running gear mounts.
    Jan 2011
    PA
    547
    Great! Thanks alot JPriami and PapaGriz, I really appreciate the help. I think I'll run the boat for a little while with the in-line (just so I can personally feel/see the difference) then get the Kintech offset.
    Jan 2011
    222
    The best part of the offset rudder is that it makes maintenance easier. After putting it in I find myself actually greasing the flexshaft where as before when I had to work around or remove the rudder it rarely happened.
    Jun 2011
    SD
    287
    Kinetic http://kintecracing.com/Miss_Geico_Upgrades.html
    Jan 2011
    PA
    547
    What motor would you guys suggest for a 4s setup?
    Jun 2011
    475
    I have the Aquacraft UL1 motor in mine and I love it. It is 2030kv. I however have very little experience in FE so you might want to see what he other guys recommend. Jason
