Page 1 of 2 12 LastLast
Results 1 to 30 of 32
Thread: 28.7mph on 2S
    Jul 2011
    Al
    134
    Default 28.7mph on 2S
    Glassy water. Running 40C 2S in series. Calc with Garmin GPS. Run time 8:00 with stock prop.
    New props should be in this week as well as two 3S cells. I'll see if she melts and makes it to 40.
    28.7 is granny.
    6,453
    Put a real prop on it
    Jun 2009
    940
    You can get into the 40's easy with just a prop swap and not burn it down. It will more likely than not burn up on 6s before long and if you go any bigger than the stock prop it will for sure soon enough. it won't be much faster than 4s with the right prop either. Make sure you get a video of it though cause it'll be cool for a little while.
    Jun 2011
    51
    V-Spec... what do you recommend for a stock setup running a pair of 2s (i.e. 4S) setup? I am looking for a bit more speed, but really want to stay reliable.
    Eric
    Jun 2009
    940
    Quote Originally Posted by Racer944 View Post
    Eric
    I'd run an x445 on it, with the stock setup it should run pretty good. A grim 42x55 will run nice too.
    Cool
    28.7mph on 2S...Running 40C 2S in series...
    This is confusing, if the packs are in series then you are NOT running on 2S but on 4S. I doubt that the ESC would turn on with just 2S.
    Saying "40C" tells us nothing useful. We also need the cell capacity to know much of anything about your packs. The brand helps too, some are well known to be over-rated. Like 40C/3300 mAh Turnigy 'nad-tech.
    Jul 2011
    Al
    134
    running TWO 2S in series. 40C 5000MAH. Deans Connectors. Always balanced. Crappy Orion Lipos
    running TWO 2S in series...
    Yes, that is 4S (14.8 volts) not 2S (7.4 volts). On the slow side for 4S as others have stated. The packs are not the reason you're relatively slow, but they probably do knock 3-5 mph off the speed compared with newer, higher quality cells.
    Jul 2011
    Al
    134
    Slow b/c of stock prop, but gives newbies an idea of what she'll do bone stock.
    Cool
    I didn't mean to imply that there was something wrong, this is apparently a pretty nice boat. It is wise of ProBoat to use a mild stock prop to avoid overheating by newbies running for too long. Actually 29 mph isn't bad at all for a stock RTR.
    Apr 2011
    tx
    1,284
    I got 38.3 out of mine running 4s with a x442 and i havent had time to set it up yet. Still doing a lot of bouncing.
    Jul 2011
    Al
    134
    Wow can't wait to put my 445 on It!
    US
    5,557
    M445 or x640..............
    Aug 2011
    JP
    3
    Mine didn't run good with an m445 but it ran good on an x445. I've got a cut down x447/3 on it right now will see how it does.
    Oct 2008
    9,488
    Quote Originally Posted by RTR Racer! View Post
    please let us know how that one works out!!
    Jul 2011
    Al
    134
    Ran tonight with x445 prop and 3S2s gens ace 5300mah 45c and burned up something. Motor or ESC not sure. Motor was way hotter than esc. Oh well I didn't really care I wanted to upgrade it anyways. Recorded 44.4mph on this setup before she blew and she was running pretty loose at that time.
    Oct 2008
    9,488
    Quote Originally Posted by Mtwinste View Post
    what are you saying? 3S2s??
    are you running two 3s packs in series or parallel??
    Jul 2011
    Al
    134
    Series. Stock electronics. Stock wiring. Series.
    Oct 2008
    9,488
    this system is ment for 4s power the way you ran it was 6s
    to much voltage with that prop possibly burnt up your esc
    Jun 2008
    896
    Mtwinste, you need to be more clear when you are posting. 3S2S. what does that mean? Does that mean 2x 3s packs which means 6s total? Or do you mean you ran a 3s pack and a 2s pack in series for 5s total?
    Jul 2011
    Al
    134
    Series. 6S total.
    Oct 2008
    9,488
    Series. 6S total.
    Jul 2011
    Al
    134
    Neither the motor nor ESC burnt. It thermaled bc it ran fine later on.
    I bought a leopard 4074 1400kv and a seaking 180A today and will run on 6s
    Oct 2008
    9,488
    good to hear about the motor and esc doing ok!
    try a different prop on the stock setup while running 4s
    you will like it..
    Jul 2011
    Al
    134
    Ran the x445 on two thunder power 2S 65C 6600mah in series. 43.4mph. Ran the batteries dead and the motor batteries esc everything was hot and even a little smoke came out from inside the hull!!!! Let it cool some and tried another pair of 2S packs and she was thermalled and wouldnt go over idle. New ESC and motor are on the way.
    Oct 2008
    9,488
    this is a solid setup from Proboat
    sounds like your looking to see smoke on every run
    6,453
    So you ran 6s on the stock setup. Probably did significant damage to the motor and esc, and then ran 6600mah packs till DEAD?! All I have to say is....WHY?
    Jul 2011
    Al
    134
    50mph on 6S but very windy and sketchy. Seaking 180. Leopard 4074 1400kv. Gens ace 6S total in series. X645 prop.
    Jul 2011
    Al
    134
    Tried again and got 54.1mph.
    Jul 2011
    Al
    134
